Today upgraded my Yellow to 2023.5.1 from 2023.4.6.
Now I cannot reach the unit using GUI anymore and I can see that the LED for Zigbee (blue) does not blink as it should.
I can access the unit using SSH and FTP, Can also check the Observer URL that say heathy.
What to do?
How can I revert to previous backup, I had the “Make backup when Installing” (or called something similar) when installing 2023.5.1?
No advice here?
I don’t want to start from beginning again as when I received my Yellow.
So much work to register all units 100+ with all the entities.
Realy need help now!!!
I took a FTP backup of everything and can see that the latest .tar file is from the moment before upgrade to 2023.5.1. But how to restore this latest .tar using SSH?
no issues here,
but you have a backup that’s a good thing,
if you use an nvme you might can concider remove it from the yellow and attach it to a pc to get a newer backup.
however, restoring a backup on the yellow was a little tricky the last time I did this.
the trick was, first fully install(just the default, it gets overwritten anyway), en migratie data to nvme, and then restore backup.
if you do this bevore migrating, somehow it keeps loading forever.
Thanks a lot for the tips!
Using nvme, so hopefully I can somehow restore everything if anything else cant be done.
Anyone with info how to restore everything from XXXXX.tar using SSH at this state?
