When I update this parameter (Qubino Mini Dimmer parameter #65) I receive the response that it is set to “1” instead of the value I’m sending… See my log below where I set the value to “25”.
I’m using the built in Z-wave Control Panel. Changing other parameters seem to work just fine…
2020-03-08 22:15:05.506 Info, Node003, Value::Set - COMMAND_CLASS_CONFIGURATION - Dimming time (soft on/off) - 65 - 1 - 25
2020-03-08 22:15:05.506 Info, Node003, Configuration::Set - Parameter=65, Value=25 Size=2
2020-03-08 22:15:05.506 Detail, Node003, Queuing (Send) ConfigurationCmd_Set (Node=3): 0x01, 0x0d, 0x00, 0x13, 0x03, 0x06, 0x70, 0x04, 0x41, 0x02, 0x00, 0x19, 0x25, 0x65, 0x8a
2020-03-08 22:15:05.506 Detail, Node003, Queuing (Send) ConfigurationCmd_Get (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x70, 0x05, 0x41, 0x25, 0x66, 0x91
2020-03-08 22:15:05.507 Detail,
2020-03-08 22:15:05.507 Info, Node003, Sending (Send) message (Callback ID=0x65, Expected Reply=0x13) - ConfigurationCmd_Set (Node=3): 0x01, 0x0d, 0x00, 0x13, 0x03, 0x06, 0x70, 0x04, 0x41, 0x02, 0x00, 0x19, 0x25, 0x65, 0x8a
2020-03-08 22:15:05.525 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-03-08 22:15:05.525 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-03-08 22:15:05.574 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x65, 0x00, 0x00, 0x05, 0x8b
2020-03-08 22:15:05.574 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x65 received (expected 0x65)
2020-03-08 22:15:05.574 Info, Node003, Request RTT 67 Average Request RTT 71
2020-03-08 22:15:05.574 Detail, Expected callbackId was received
2020-03-08 22:15:05.574 Detail, Expected reply was received
2020-03-08 22:15:05.574 Detail, Message transaction complete
2020-03-08 22:15:05.574 Detail, Node003, Removing current message
2020-03-08 22:15:05.574 Info, Node003, Sending (Send) message (Callback ID=0x66, Expected Reply=0x04) - ConfigurationCmd_Get (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x70, 0x05, 0x41, 0x25, 0x66, 0x91
2020-03-08 22:15:05.587 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-03-08 22:15:05.587 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-03-08 22:15:05.641 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x66, 0x00, 0x00, 0x06, 0x8b
2020-03-08 22:15:05.641 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x66 received (expected 0x66)
2020-03-08 22:15:05.641 Info, Node003, Request RTT 66 Average Request RTT 68
2020-03-08 22:15:05.641 Detail, Expected callbackId was received
2020-03-08 22:15:05.777 Detail, Node003, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x03, 0x05, 0x70, 0x06, 0x41, 0x01, 0x01, 0xc1
2020-03-08 22:15:05.777 Info, Node003, Response RTT 202 Average Response RTT 184
2020-03-08 22:15:05.777 Detail, Node003, Refreshed Value: old value=1, new value=1, type=short
2020-03-08 22:15:05.777 Detail, Node003, Changes to this value are not verified
2020-03-08 22:15:05.777 Info, Node003, Received Configuration report: Parameter=65, Value=1
2020-03-08 22:15:05.777 Detail, Node003, Expected reply and command class was received
2020-03-08 22:15:05.777 Detail, Node003, Message transaction complete
2020-03-08 22:15:05.777 Detail, Node003, Removing current message
2020-03-08 22:15:05.777 Detail, Node003, Notification: ValueChanged
