Hi peeps.
I’ve tried searching the internet and the forums for this problem, but they all seem different from mine.
So i hope someone can lead me in the right direction.
Using HomeAssistant 3.9 and want to upgrade to 3.10 on a RPI 3 with a SD micro card.
At first i got errors from customui, so i completely disabled it and removed the files from the system.
But now it still doesn’t want to update… I get the following messages in the logs:
20-03-04 12:26:22 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
20-03-04 12:26:22 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
20-03-04 12:34:30 INFO (MainThread) [hassio.hassos] Fetch OTA update from https://github.com/home-assistant/operating-system/releases/download/3.10/hassos_rpi3-3.10.raucb
20-03-04 12:34:35 WARNING (MainThread) [hassio.hassos] Can't fetch versions from https://github.com/home-assistant/operating-system/releases/download/3.10/hassos_rpi3-3.10.raucb: Cannot connect to host github.com:443 ssl:None [Try again]
I already changed the Hostname to something else (saw it on the forums) and shutdown HA a couple of times now (around 3 times… do i need to do more??)
When i copy/paste the url in google chrome, it directly downloads the update file to my laptop.
Also tried to copy the update file to a usb stick and put it in the RPI with the option “import from USB” within HA. But nothing happens.
Is there anybody who ran into the same problem?
