Hi, I cannot update hass. I don’t know why. I already removed al .pyc files. But didn’t work out.
I have a back-up from a couple of weeks ago. So if this is not a known problem I will try to update again after I put the backup again on the bbb.
This is the output I have:
hass@beaglebone:/home/bart$ source /srv/hass/hass_venv/bin/activate
(hass_venv) hass@beaglebone:/home/bart$ pip3 install --upgrade homeassistant
File "/srv/hass/hass_venv/bin/pip3", line 7, in <module>
from pip import main
File "/srv/hass/hass_venv/lib/python3.4/site-packages/pip/__init__.py", line 14, in <module>
from pip.utils import get_installed_distributions, get_prog
File "/srv/hass/hass_venv/lib/python3.4/site-packages/pip/utils/__init__.py", line 27, in <module>
from pip._vendor import pkg_resources
File "/srv/hass/hass_venv/lib/python3.4/site-packages/pip/_vendor/pkg_resources/__init__.py", line 71, in <module>
__import__('pip._vendor.packaging.requirements')
File "<frozen importlib._bootstrap>", line 2237, in _find_and_load
File "<frozen importlib._bootstrap>", line 2226, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1200, in _load_unlocked
File "<frozen importlib._bootstrap>", line 1129, in _exec
File "<frozen importlib._bootstrap>", line 1467, in exec_module
File "<frozen importlib._bootstrap>", line 1570, in get_code
File "<frozen importlib._bootstrap>", line 656, in _compile_bytecode
ValueError: bad marshal data (unknown type code)
