Hi, I always have trouble updating HA, I get this kind of error
pi @ raspberrypi: ~ $ pip3 install homeassistant == 0.86.4
File “/ usr / bin / pip3”, line 9, in
from pip import main
ImportError: can not import name ‘main’
from the support site I never find the right instruction, who can help me?
Thank you
How did you install HA? (Unfortunately there are several choices.) If you did a Python Virtual Environment install of some sort, you need to first switch into that venv. And you might need to switch to the user account that is running HA, too. This is what I usually do to upgrade:
sudo systemctl stop [email protected]
sudo -u homeassistant -H -s
source /srv/homeassistant/bin/activate
pip3 install --upgrade homeassistant
deactivate
exit
sudo systemctl start [email protected]
Ok everything is ok, finally the procedure you indicated was successful, thanks again …
