I’m seeing a series of errors now every time I do a server restart that I’ve not seen before. Most are warnings of zones, groups, and input_text, timers, sensors and other components taking over 10 seconds.
I also have binary_sensor.updater as unavailable though on one restart I saw that it had timed out.
The one error I’m not sure of is:
2020-07-19 00:12:15 ERROR (MainThread) [homeassistant.components.webhook] Error processing webhook 0a115be2c4b0f95748e6049f13d65d87e48dbaecdefcd0f11dbef6f4e66aaf87
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 97, in async_handle_webhook
response = await webhook["handler"](hass, webhook_id, request)
File "/usr/src/homeassistant/homeassistant/components/mobile_app/webhook.py", line 192, in handle_webhook
WEBHOOK_COMMANDS[webhook_type](hass, config_entry, webhook_payload)
concurrent.futures._base.CancelledError
Are these real issues or just a timing thing? I am bothered that I didn’t get the update notification for 112.5. About the time that came out, I entered the binary sensor in my configuration.yaml below. Because it was at the same time, I’m now wondering if I violated some sequence requirement that is causing the update sensor to be unavailable. Also, I tried just defining it as a sensor along with my others, but config check doesn’t like the value_template statement.
Anyone got any ideas?
binary_sensor:
sensors:
garage_motion_sensor:
value_template: '{% if is_state("sensor.linear_nortek_security_control_llc_wapirz_1_motion_sensor_alarm_level", "0") %}False{% else %}True{% endif %}'
friendly_name: "Garage Motion Sensor"
device_class: motion
BTW I’m running HASS.IO on a raspberry pi 4 and I’ve tried a full reboot without luck.
