UPDATE Sensor/Notification Configuration. . . because I like to overcomplicate things
No custom elements used
The standard update sensor doesn’t seem to work every time, at least for me, so I made one as I like it.
You can only use the persistent notification, or the card, or add anything you want to it.
I’m experimenting with this setup for a few updates; I had pushbullet notifications for it…and at some point I even had Google Assistant read out the update version if one is available (and if I was home), but this seems to be the most practical configuration for me so far, so maybe someone finds something useful here.
My update notification configuration consists of a Lovelace entity that can be placed anywhere you want and it will be hidden unless there is an update available.
Once an update is available, a persistent notification will be displayed and it will remain there over restarts until Home Assistant is updated.
The notification will also have a link where you can find the release notes and display the current version.
  - platform: rest        # Home Assistant LATEST Version
    resource: https://pypi.python.org/pypi/homeassistant/json
    value_template: '{{ value_json.info.version }}'
    #scan_interval: 21600 # Optional scanning interval
  - platform: version     # Home Assistant CURRENT Version
  - platform: template    # Home Assistant UPDATE AVAILABLE
    sensors:
      update_available:
        friendly_name: "Updater"
        value_template: >-
          {% if (states.sensor.update.state) > (states.sensor.version.state) %}
            {{states.sensor.update.state}}
          {% else %}
            LATEST
          {% endif %}
Place this anywhere you want it to show up in Lovelace:
ui-lovelace.yaml
- type: conditional                   # Update Notification
  conditions:
  - entity: sensor.update_available
    state_not: "LATEST"
  card:
    type: entities
    entities:
    - sensor.update_available
    theme: updater
automation:
- id: homeassistant_update            # Update Notification
  alias: 'UPDATE AVAILABLE'
  initial_state: on
  - platform: homeassistant
    event: start
  - platform: state
    entity_id: sensor.update_available
  condition:
    condition: and
    conditions:
    - condition: template
      value_template: >
        {{ not is_state('sensor.update_available', 'LATEST') }}
      value_template: >
        {{ not is_state('sensor.update_available', 'unavailable') }}
  - service: persistent_notification.create
      title: Version {{states.sensor.update.state}} available!
      message: >
        Release notes for verison **{{states.sensor.update.state}}** are available [**HERE**](https://www.home-assistant.io/latest-release-notes/)
        Current version is {{states.sensor.version.state}}
customize:
sensor.update:
  icon: mdi:cloud-upload
  hidden: true
sensor.version:
  icon: mdi:cloud-upload-outline
  hidden: true
sensor.update_available:
  friendly_name: "NEW VERSION AVAILABLE"
  icon: mdi:hand-okay
  hidden: true
theme:
  updater:
    paper-card-background-color: "var(--accent-color)"
