A few weeks ago my very tiny workflow stopped working. I made sure nodered and plugins & Ha is updated fully but it does not help. Updates to sensors is reflected into NodeRed though.
What can I check to debug this?
If you go to the entity inside ha, switch.smart_plug_2, does it work?
Thanks for the reply.
If I go into HA and change the status from on to off it is not reflected on the switch. If I change the status on the switch (there is a button for turning off/on) that change is reflected into HA.
So it seems like it’s only one way.
What is my next step?
If you can’t turn the bulb on/off in home assistant, it will not work from node red. You can try removing and reinstalling the light.
That makes sense. I have more than one switch and the others are the same.
To the next guy who comes along - I really did not find the exact issue but after a reset of my conbee iii and re-adding the devices it seems to work better.
