UPDATE - System OS to 6.0
Hi.
After update the System to 6.0 my homeassistant not boot until i press CTRL-D.
I Restore one backup to test it my data are corrupt and update OS to 6.0 again and happens too.
There are any way to fix it and let it boot without press CTRL-D ?
What version did you update from? Is this on a VM?
It looks like file system corruption. It might be possible to fix it, but I think the safest approach is to take a full Snapshot, shutdown the system and start over with a new installation.
Yes, im using it from VM with PROXMOX. i did update the OS from latest version 5.13.
In version 5.13 it work’s good. i will try start over with new installation, with full snapshot :wink:
Finally after half year I fixed it. The filesystem had error. I did:
  • downloaded ubuntu iso on host machine
  • attached iso as CD-ROM
  • turned off UEFI
  • turned off boot from hard drive
  • set up CD-ROM as first device to boot
  • started virtual machine and selected boot from CD-ROM
  • after ubuntu started I launched gparted, selected disk with HA and run check/fix on data partition (twice)
  • powered off virtual device
  • unchecked boot from CD-ROM, checked boot from HD and moved it to first position
  • moved HD in boot order to top
  • started the virtual machine. no Ctrl-D was required
