kiryear
October 30, 2020, 10:57am
1
Hey,
I recently have problems with entities values updates of temperature and humidity.
I have 1 FGBS222 with a DHT22 (AM2302) in my bashroom and an other one in a cupboard.
Since few days, weeks, the values doesn’t update.
I need to force the update via zwave integration config :
Select the node > select the entity > clic on update entity
I tried to change the intensity polling values of my entities but its not working
I tried to change the parameters 67 et 68 of my FGBS nodes but its not working
I tried to periodical call the zwave.refresh_entity service but it only can call the zwave entity but not a sensor entity.
There my zwcfg.xml for one of the 2 nodes (the other one is the same) :
Any idea to solve my problem ?
Thks
kiryear
October 30, 2020, 10:58am
2
Part 1 :
<Node id="34" name="" location="" basic="4" generic="7" specific="1" roletype="5" devicetype="3072" nodetype="0" type="Notification Sensor" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="10f" name="FIBARO System">
<Product type="502" id="1000" name="FGBS222 Smart Implant" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="5" setasreport="true">
<Instance index="1" />
<Value type="byte" genre="basic" instance="1" index="0" label="Basic" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="255" />
</CommandClass>
<CommandClass id="34" name="COMMAND_CLASS_APPLICATION_STATUS" version="1" request_flags="5" innif="true">
<Instance index="1" endpoint="1" />
<Instance index="2" endpoint="2" />
<Instance index="3" endpoint="3" />
<Instance index="4" endpoint="4" />
<Instance index="5" endpoint="5" />
<Instance index="6" endpoint="6" />
<Instance index="7" endpoint="7" />
<Instance index="8" endpoint="8" />
<Instance index="9" endpoint="9" />
</CommandClass>
<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="5" innif="true">
<Instance index="1" endpoint="5" />
<Instance index="2" endpoint="6" />
<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="user" instance="2" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
</CommandClass>
<CommandClass id="48" name="COMMAND_CLASS_SENSOR_BINARY" version="1">
<Value type="bool" genre="user" instance="1" index="0" label="Sensor" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
</CommandClass>
<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="11" request_flags="1" innif="true">
<Instance index="1" endpoint="3" />
<Instance index="2" endpoint="4" />
<Instance index="3" endpoint="7" />
<Instance index="4" endpoint="8" />
<Instance index="5" endpoint="9" />
<Value type="decimal" genre="user" instance="1" index="15" label="Voltage" units="V" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="10.92" />
<Value type="decimal" genre="user" instance="2" index="15" label="Voltage" units="V" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="10.36" />
<Value type="decimal" genre="user" instance="3" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="30.2" />
<Value type="decimal" genre="user" instance="4" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="18.7" />
<Value type="decimal" genre="user" instance="5" index="5" label="Relative Humidity" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="70.9" />
</CommandClass>
<CommandClass id="86" name="COMMAND_CLASS_CRC_16_ENCAP" version="1" request_flags="5" innif="true">
</CommandClass>
<CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="5" innif="true">
</CommandClass>
<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="5" innif="true" scenecount="0">
<Value type="int" genre="system" instance="1" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
</CommandClass>
<CommandClass id="94" name="COMMAND_CLASS_ZWAVEPLUS_INFO" version="1" request_flags="5" innif="true">
<Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
<Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="3072" />
<Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="3072" />
<Value type="byte" genre="system" instance="2" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="short" genre="system" instance="2" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="short" genre="system" instance="2" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="byte" genre="system" instance="3" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="short" genre="system" instance="3" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="short" genre="system" instance="3" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="byte" genre="system" instance="4" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="short" genre="system" instance="4" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="short" genre="system" instance="4" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="byte" genre="system" instance="5" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="short" genre="system" instance="5" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="short" genre="system" instance="5" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="byte" genre="system" instance="6" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="short" genre="system" instance="6" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="short" genre="system" instance="6" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="byte" genre="system" instance="7" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="short" genre="system" instance="7" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="short" genre="system" instance="7" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="byte" genre="system" instance="8" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="short" genre="system" instance="8" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="short" genre="system" instance="8" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="byte" genre="system" instance="9" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="short" genre="system" instance="9" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="short" genre="system" instance="9" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
</CommandClass>
<CommandClass id="96" name="COMMAND_CLASS_MULTI_INSTANCE/CHANNEL" version="4" request_flags="1" innif="true" mapping="endpoints">
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="5" innif="true">
<Value type="list" genre="config" instance="1" index="20" label="Input 1 operating mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="2" size="1">
<Help>This parameter allows to choose mode of 1st input (IN1). Change it depending on connected device.</Help>
<Item label="Normally closed alarm input" value="0" />
<Item label="Normally open alarm input" value="1" />
<Item label="Monostable button" value="2" />
<Item label="Bistable button" value="3" />
<Item label="Analog input without internal pull-up" value="4" />
<Item label="Analog input with internal pullup" value="5" />
</Value>
<Value type="list" genre="config" instance="1" index="21" label="Input 2 operating mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="2" size="1">
<Help>This parameter allows to choose mode of 2nd input (IN2). Change it depending on connected device.</Help>
</Value>
<Value type="list" genre="config" instance="1" index="24" label="Inputs orientation" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Help>This parameter allows reversing operation of IN1 and IN2 inputs without changing the wiring. Use in case of incorrect wiring.</Help>
<Item label="Default (IN1 - 1st input, IN2 - 2nd input)" value="0" />
<Item label="Reversed (IN1 - 2nd input, IN2 - 1st input)" value="1" />
</Value>
<Value type="list" genre="config" instance="1" index="25" label="Outputs orientation" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Help>This parameter allows reversing operation of OUT1 and OUT2 inputs without changing the wiring. Use in case of incorrect wiring.</Help>
<Item label="Default (OUT1 - 1st output, OUT2 - 2nd output)" value="0" />
<Item label="Reversed (OUT1 - 2nd output, OUT2 - 1st output)" value="1" />
</Value>
<Value type="byte" genre="config" instance="1" index="40" label="Input 1 sent scenes" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0">
<Help>This parameter defines which actions result in sending scene ID and attribute assigned to them. Parameter is relevant only if parameter 20 is set to 2 or 3. bitmask. 0 => No scenes sent. 1 => Key pressed 1 time. 2 => Key pressed 2 times. 4 => Key pressed 3 times. 8 => Key hold down and key released.</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="41" label="Input 2 sent scenes" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0">
<Help>This parameter defines which actions result in sending scene ID and attribute assigned to them. Parameter is relevant only if parameter 21 is set to 2 or 3. bitmask. 0 => No scenes sent. 1 => Key pressed 1 time. 2 => Key pressed 2 times. 4 => Key pressed 3 times. 8 => Key hold down and key released.</Help>
</Value>
<Value type="short" genre="config" instance="1" index="47" label="Input 1 value sent to 2nd association group when activated" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="255">
<Help>This parameter defines value sent to devices in 2nd association group when IN1 input is triggered (using Basic Command Class). Available settings: 0-255. Default setting: 255.</Help>
</Value>
<Value type="short" genre="config" instance="1" index="49" label="Input 1 value sent to 2nd association group when deactivated" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="255">
<Help>This parameter defines value sent to devices in 2nd association group when IN1 input is deactivated (using Basic Command Class). Available settings: 0-255. Default setting: 255.</Help>
</Value>
<Value type="short" genre="config" instance="1" index="52" label="Input 2 value sent to 3rd association group when activated" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="255">
<Help>This parameter defines value sent to devices in 3rd association group when IN2 input is triggered (using Basic Command Class). Available settings: 0-255. Default setting: 255.</Help>
</Value>
<Value type="short" genre="config" instance="1" index="54" label="Input 2 value sent to 3rd association group when deactivated" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="255">
<Help>This parameter defines value sent to devices in 3rd association group when IN2 input is deactivated (using Basic Command Class). Available settings: 0-255. Default setting: 255.</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="63" label="Analog inputs minimal change to report" units="0.1v" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="100" value="5">
<Help>This parameter defines minimal change (from the last reported) of analog input value that results in sending new report. Parameter is relevant only for analog inputs (parameter 20 or 21 set to 4 or 5). Available settings: 0 - (reporting on change disabled). 1-100 (0.1-10V, 0.1V step). Default setting: 5 (0.5V).</Help>
</Value>
<Value type="short" genre="config" instance="1" index="64" label="Analog inputs periodical reports" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="32400" value="0">
<Help>This parameter defines reporting period of analog inputs value. Periodical reports are independent from changes in value (parameter 63). Parameter is relevant only for analog inputs (parameter 20 or 21 set to 4 or 5). Available settings: 0 (periodical reports disabled). 60-32400 (60s-9h). Default setting: 0 (periodical reports disabled).</Help>
</Value>
<Value type="short" genre="config" instance="1" index="65" label="Internal temperature sensor minimal change to report" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="5">
<Help>This parameter defines minimal change (from the last reported) of internal temperature sensor value that results in sending new report. Available settings: 0 - (reporting on change disabled). 1-255 (0.1-25.5C). Default setting: 5 (0.5C).</Help>
</Value>
<Value type="short" genre="config" instance="1" index="66" label="Internal temperature sensor periodical reports" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="32400" value="0">
<Help>This parameter defines reporting period of internal temperature sensor value. Periodical reports are independent from changes in value (parameter 65). Available settings: 0 (periodical reports disabled). 60-32400 (60s-9h). Default setting: 0 (periodical reports disabled).</Help>
</Value>
<Value type="short" genre="config" instance="1" index="67" label="External sensors minimal change to report" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="5">
<Help>This parameter defines minimal change (from the last reported) of external sensors values (DS18B20 or DHT22) that results in sending new report. Parameter is relevant only for connected DS18B20 or DHT22 sensors. Available settings: 0 - (reporting on change disabled). 1-255 (0.1-25.5 units). Default setting: 5 (0.5 units)</Help>
</Value>
<Value type="short" genre="config" instance="1" index="68" label="External sensors periodical reports" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="32400" value="0">
<Help>This parameter defines reporting period of analog inputs value. Periodical reports are independent from changes in value (parameter 67). Parameter is relevant only for connected DS18B20 or DHT22 sensors. Available settings: 0 - (periodical reports disabled). 60-32400 (60s-9h). Default setting: 0 (periodical reports disabled).</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="150" label="Input 1 sensitivity" units="10ms" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="100" value="10">
<Help>This parameter defines the inertia time of IN1 input in alarm modes. Adjust this parameter to prevent bouncing or signal disruptions. Parameter is relevant only if parameter 20 is set to 0 or 1 (alarm mode). Available settings: 1-100 (10ms-1000ms, 10ms step). Default setting: 10 (100ms).</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="151" label="Input 2 sensitivity" units="10ms" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="100" value="10">
<Help>This parameter defines the inertia time of IN2 input in alarm modes. Adjust this parameter to prevent bouncing or signal disruptions. Parameter is relevant only if parameter 21 is set to 0 or 1 (alarm mode). Available settings: 1-100 (10ms-1000ms, 10ms step). Default setting: 10 (100ms).</Help>
</Value>
<Value type="short" genre="config" instance="1" index="152" label="Input 1 delay of alarm cancellation" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="3600" value="0">
<Help>This parameter defines additional delay of cancelling the alarm on IN1 input. Parameter is relevant only if parameter 20 is set to 0 or 1 (alarm mode). Available settings: 0 - no delay. 1-3600s. Default setting: 0 (no delay).</Help>
</Value>
<Value type="short" genre="config" instance="1" index="153" label="Input 2 delay of alarm cancellation" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="3600" value="0">
<Help>This parameter defines additional delay of cancelling the alarm on IN2 input. Parameter is relevant only if parameter 21 is set to 0 or 1 (alarm mode). Available settings: 0 - no delay. 1-3600s. Default setting: 0 (no delay).</Help>
</Value>
<Value type="list" genre="config" instance="1" index="154" label="Output 1 logic of operation" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Help>This parameter defines logic of OUT1 output operation.</Help>
<Item label="contacts normally open" value="0" />
<Item label="contacts normally closed" value="1" />
</Value>
<Value type="list" genre="config" instance="1" index="155" label="Output 2 logic of operation" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Help>This parameter defines logic of OUT2 output operation.</Help>
</Value>
<Value type="short" genre="config" instance="1" index="156" label="Output 1 auto off" units="0.1s" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="27000" value="0">
<Help>This parameter defines time after which OUT1 will be automatically deactivated. Available settings: 0 - auto off disabled. 1-27000 (0.1s-45min, 0.1s step). Default setting: 0 (auto off disabled).</Help>
</Value>
<Value type="short" genre="config" instance="1" index="157" label="Output 2 auto off" units="0.1s" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="27000" value="0">
<Help>This parameter defines time after which OUT2 will be automatically deactivated. Available settings: 0 - auto off disabled. 1-27000 (0.1s-45min, 0.1s step). Default setting: 0 (auto off disabled).</Help>
</Value>
kiryear
3
Part 2
</CommandClass>
<CommandClass id="113" name="COMMAND_CLASS_ALARM" version="8" request_flags="1" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="2" label="SourceNodeId" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="10" label="Burglar" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="254" />
<Value type="byte" genre="user" instance="2" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="2" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="2" index="2" label="SourceNodeId" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="2" index="10" label="Burglar" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="254" />
<Value type="byte" genre="user" instance="3" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="3" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="3" index="2" label="SourceNodeId" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="3" index="12" label="System" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="254" />
<Value type="byte" genre="user" instance="4" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="4" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="4" index="2" label="SourceNodeId" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="4" index="12" label="System" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
<Value type="byte" genre="user" instance="5" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="5" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="5" index="2" label="SourceNodeId" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="5" index="12" label="System" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="5" innif="true">
</CommandClass>
<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="5" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Normal" value="0" />
<Item label="-1dB" value="1" />
<Item label="-2dB" value="2" />
<Item label="-3dB" value="3" />
<Item label="-4dB" value="4" />
<Item label="-5dB" value="5" />
<Item label="-6dB" value="6" />
<Item label="-7dB" value="7" />
<Item label="-8dB" value="8" />
<Item label="-9dB" value="9" />
</Value>
<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Failed" value="0" />
<Item label="Success" value="1" />
<Item label="In Progress" value="2" />
</Value>
<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
</CommandClass>
<CommandClass id="117" name="COMMAND_CLASS_PROTECTION" version="1" request_flags="5" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Unprotected" value="0" />
<Item label="Protection by Sequence" value="1" />
<Item label="No Operation Possible" value="2" />
</Value>
<Value type="list" genre="system" instance="2" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="5" innif="true">
<Associations num_groups="3">
<Group index="1" max_associations="1" label="Lifeline" auto="true" multiInstance="true">
<Node id="1" />
</Group>
<Group index="2" max_associations="5" label="Input IN1" auto="false" multiInstance="true" />
<Group index="3" max_associations="5" label="Input IN2" auto="false" multiInstance="true" />
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="5" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="6.02" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="5.01" />
</CommandClass>
<CommandClass id="142" name="COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION" version="1" request_flags="5" innif="true">
<Node id="1" />
</Group>
</Associations>
</CommandClass>
<CommandClass id="152" name="COMMAND_CLASS_SECURITY" version="1" request_flags="5" innif="true">
<Value type="bool" genre="system" instance="1" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="system" instance="2" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="system" instance="3" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="system" instance="4" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="system" instance="5" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="system" instance="6" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="system" instance="7" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="system" instance="8" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="system" instance="9" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
</CommandClass>
</CommandClasses>
</Node>
kiryear
November 21, 2020, 8:46pm
4
Any idea why my entities values doesn’t update ?
