I’m attempting to follow the instructions to integrate our Alexa following the [Alexa Instructions] with Home Assistant but seem to be stuck. It appears the Alexa instructions are a bit out of date?
There seems to be something missing between these steps:
Click the yellow “Add a new skill” button in the top right
Skill Type: Custom Interaction Model (default)
Name: Home Assistant
Invocation name: home assistant (or be creative, up to you)
Version: 1.0
Endpoint:
Last month I followed the instructions for Google Home and it worked right away. Hopefully with an update (or clarifications) this one will be too. Thanks in advance
Where it says “You can now test your work”, I followed the directions and the test was a success. The JSON results showed every device. BUT when I try to “set it up for use” by telling Alexa to Discover My Devices - it finds nothing. Any suggestions?
