Update TI LAUNCHXL-CC1352P-2 without loosing the config/pairing
subject says it all.
Using that FW: https://github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator/Z-Stack_3.x.0/bin
Thx. Cu!
back up / restore:
Thank you.
Zigbee2MQTT include an update which does not need any special handling.
There is nothing equivalent for ZHA?
Cu!
zgpy-znp is the backend lib used for the TI sticks in ZHA. there is a lot of work going into a universal back up format right now and hopefully it will get added to the ZHA config panel at some point.
