First of all, thank you to all who have put and continue to put the effort into this project!
My goal is to have a light turn off after sunset based on an offset that is set via an input field.
I have set up an automation that turns off the light with the trigger of sunset + offset and this works. I didn’t see a way to modify the offset but I did see that I can provide the time to turn off via a helper so I created a datetime input helper and a drop down helper to select the offset.
I created a script to change the datetime helper to = sunset + new offset:
set dt_off_light:
alias: Light off time 1
sequence:
- service: input_datetime.set_datetime
entity_id: input_datetime.light_off_time
datetime: >-
"{% set offset = strptime(states('input_select.light_off_offset')+':00:00','%H:%M:%S') %}"
"{% set offset = as_timestamp(strptime(offset, '%H:%M:%S')) %}"
"{% set sunset = as_timestamp(states.sun.sun.attributes.next_setting) %}"
"{{ (sunset + offset) | timestamp_custom('%H:%M') }}"
I also tried:
set dt_off_light:
alias: light off time
sequence:
datetime: "{{((as_timestamp(states.sun.sun.attributes.next_setting)) + (strptime(states('input_select.light_off_offset')+':00:00','%H:%M:%S') | as_timestamp(strptime(offset, '%H:%M:%S')))) | timestamp_custom('%H:%M') }}"
neither works. When I run the script via an automation I get:
So I think I have at least 2 issues:
The changed value sunset + new offset is not what I’m expecting, I think it’s not in the right time zone
When I use the value for next_setting in the script The value is not stored. If I change it to now() the value stored in the datetime helper is changed when I change the selected item in the dropdown helper
Thank you again for all the support offered to those of us just starting out on this journey!
