UI will not load, no errors in the core log, and a non-specific API error in the supervisor logs. Tried a roll back from the command line which instantly return saying it has been successful when clearly it has failed.
~ $ ha core update --version 0.116.4
Processing... Done.
Command completed successfully.
~ $ ha core info
arch: armv7
audio_input: null
audio_output: null
boot: true
image: homeassistant/raspberrypi3-homeassistant
ip_address: 172.30.32.1
last_version: 0.117.0
machine: raspberrypi3
port: 8123
ssl: true
update_available: false
version: 0.117.0
version_latest: 0.117.0
wait_boot: 600
watchdog: true
Totally stuck now, any suggestions ?
Core Logs
~ $ ha core logs
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[11:47:17] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2020-10-29 11:47:54 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for govee which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-10-29 11:47:54 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
[fix-attrs.d] done.
[14:41:10] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
2020-10-29 14:41:48 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-10-29 14:41:48 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for govee which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
[fix-attrs.d] done.
[14:53:31] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
2020-10-29 14:54:05 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for govee which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-10-29 14:54:05 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
Supervisor Logs
~ $ ha supervisor logs
20-10-29 14:47:39 ERROR (MainThread) [supervisor.homeassistant.api] Error on call https://172.30.32.1:8123/api/config:
20-10-29 14:48:37 INFO (MainThread) [supervisor.api.security] /supervisor/logs access from core_ssh
20-10-29 14:48:55 INFO (MainThread) [supervisor.api.security] /supervisor/logs access from core_ssh
[fix-attrs.d] done.
[14:52:02] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
[14:52:03] INFO: Starting local supervisor watchdog...
20-10-29 14:52:11 INFO (MainThread) [__main__] Initializing Supervisor setup
20-10-29 14:52:11 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
20-10-29 14:52:11 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/armv7-hassio-supervisor with version 2020.10.0
20-10-29 14:52:12 INFO (MainThread) [__main__] Setting up Supervisor
20-10-29 14:52:12 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
20-10-29 14:52:13 INFO (MainThread) [supervisor.host.info] Updating local host information
20-10-29 14:52:13 INFO (MainThread) [supervisor.host.services] Updating service information
20-10-29 14:52:14 INFO (MainThread) [supervisor.host.network] Updating local network information
20-10-29 14:52:15 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-10-29 14:52:15 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
20-10-29 14:52:15 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
20-10-29 14:52:15 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-dns with version 2020.10.0
20-10-29 14:52:15 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
20-10-29 14:52:15 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_dns application
20-10-29 14:52:18 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS homeassistant/armv7-hassio-dns with version 2020.10.0 - 172.30.32.3
20-10-29 14:52:18 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-10-29 14:52:19 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-audio with version 17
20-10-29 14:52:19 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
20-10-29 14:52:19 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_audio application
20-10-29 14:52:31 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio homeassistant/armv7-hassio-audio with version 17 - 172.30.32.4
20-10-29 14:52:31 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-cli with version 2020.10.0
20-10-29 14:52:31 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
20-10-29 14:52:31 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_cli application
20-10-29 14:52:47 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI homeassistant/armv7-hassio-cli with version 2020.10.0 - 172.30.32.5
20-10-29 14:52:47 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-observer with version 2020.10.1
20-10-29 14:52:47 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-multicast with version 3
20-10-29 14:52:47 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
20-10-29 14:52:47 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_multicast application
20-10-29 14:52:49 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast homeassistant/armv7-hassio-multicast with version 3 - Host
20-10-29 14:52:49 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
20-10-29 14:52:49 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/raspberrypi3-homeassistant with version 0.117.0
20-10-29 14:52:49 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 3 Home Assistant secrets
20-10-29 14:52:50 INFO (MainThread) [supervisor.hassos] Detect HassOS 4.15 / BootSlot A
20-10-29 14:52:52 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
20-10-29 14:52:52 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/44c60309 repository
20-10-29 14:52:52 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
20-10-29 14:52:52 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/cebe7a76 repository
20-10-29 14:52:53 INFO (MainThread) [supervisor.store] Loading add-ons from store: 68 all - 68 new - 0 remove
20-10-29 14:52:53 INFO (MainThread) [supervisor.addons] Found 6 installed add-ons
20-10-29 14:52:53 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to hassioaddons/adguard-armv7 with version 2.5.1
20-10-29 14:52:53 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-ssh with version 8.9.1
20-10-29 14:52:53 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-duckdns with version 1.12.1
20-10-29 14:52:53 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-check_config with version 3.6.0
20-10-29 14:52:53 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-configurator with version 5.1.0
20-10-29 14:52:53 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to sabeechen/hassio-google-drive-backup-armv7 with version 3.12
20-10-29 14:52:53 INFO (MainThread) [supervisor.snapshots] Found 5 snapshot files
20-10-29 14:52:54 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
20-10-29 14:52:54 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
20-10-29 14:52:54 INFO (MainThread) [__main__] Running Supervisor
20-10-29 14:52:55 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
20-10-29 14:52:55 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
20-10-29 14:52:55 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
20-10-29 14:52:55 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 3 add-ons
20-10-29 14:52:55 INFO (SyncWorker_5) [supervisor.docker.interface] Cleaning addon_core_ssh application
20-10-29 14:52:59 INFO (SyncWorker_5) [supervisor.docker.addon] Starting Docker add-on homeassistant/armv7-addon-ssh with version 8.9.1
20-10-29 14:52:59 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_core_duckdns application
20-10-29 14:53:14 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/armv7-addon-duckdns with version 1.12.1
20-10-29 14:53:14 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_a0d7b954_adguard application
20-10-29 14:53:24 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on hassioaddons/adguard-armv7 with version 2.5.1
20-10-29 14:53:29 INFO (SyncWorker_2) [supervisor.docker.interface] Starting homeassistant
20-10-29 14:53:29 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_adguard
20-10-29 14:53:30 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
20-10-29 14:53:44 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_adguard
20-10-29 14:54:13 INFO (MainThread) [supervisor.api.security] /supervisor/logs access from core_ssh
20-10-29 14:55:41 INFO (MainThread) [supervisor.api.security] /supervisor/logs access from core_ssh
20-10-29 14:55:56 INFO (MainThread) [supervisor.api.security] /core/logs access from core_ssh
20-10-29 14:56:02 ERROR (MainThread) [supervisor.homeassistant.api] Error on call https://172.30.32.1:8123/api/config:
20-10-29 14:56:28 INFO (MainThread) [supervisor.api.security] /supervisor/logs access from core_ssh
20-10-29 14:57:09 ERROR (MainThread) [supervisor.homeassistant.api] Error on call https://172.30.32.1:8123/api/config:
20-10-29 14:57:46 INFO (MainThread) [supervisor.api.security] /core/update access from core_ssh
20-10-29 14:57:46 ERROR (MainThread) [supervisor.utils] Can't execute update while a task is in progress
20-10-29 14:58:16 ERROR (MainThread) [supervisor.homeassistant.api] Error on call https://172.30.32.1:8123/api/config:
20-10-29 14:59:23 ERROR (MainThread) [supervisor.homeassistant.api] Error on call https://172.30.32.1:8123/api/config:
20-10-29 14:59:49 INFO (MainThread) [supervisor.api.security] /core/update access from core_ssh
20-10-29 14:59:49 ERROR (MainThread) [supervisor.utils] Can't execute update while a task is in progress
20-10-29 14:59:55 INFO (MainThread) [supervisor.api.security] /core/update access from core_ssh
20-10-29 14:59:55 ERROR (MainThread) [supervisor.utils] Can't execute update while a task is in progress
20-10-29 15:00:14 INFO (MainThread) [supervisor.api.security] /core/info access from core_ssh
20-10-29 15:00:30 ERROR (MainThread) [supervisor.homeassistant.api] Error on call https://172.30.32.1:8123/api/config:
20-10-29 15:00:30 INFO (MainThread) [supervisor.api.security] /core/logs access from core_ssh
20-10-29 15:01:37 ERROR (MainThread) [supervisor.homeassistant.api] Error on call https://172.30.32.1:8123/api/config:
20-10-29 15:02:44 ERROR (MainThread) [supervisor.homeassistant.api] Error on call https://172.30.32.1:8123/api/config:
20-10-29 15:03:06 INFO (MainThread) [supervisor.api.security] /core/logs access from core_ssh
20-10-29 15:03:51 ERROR (MainThread) [supervisor.homeassistant.api] Error on call https://172.30.32.1:8123/api/config:
20-10-29 15:04:18 INFO (MainThread) [supervisor.api.security] /supervisor/logs access from core_ssh
