Hi
I did update my HA to 0.42.2 right now, usally its no problems.
But this time the sensor.rfxtrx did stop working.
This is what I see in the logs:
Please report the following info at http://bit.ly/2ogP58T : switch.vera, verisure, vera, sensor.history_stats, updater, input_select, group, logbook, panel_iframe, camera.mjpeg, light, scene.homeassistant, switch.rfxtrx, ifttt, cover, camera.verisure, config, cover.vera, binary_sensor.vera, climate.vera, light.vera, recorder, sensor.vera, zone, lock.verisure, climate, tts, config.core, alarm_control_panel.verisure, scene, camera.ffmpeg, switch.verisure, automation, camera, sensor.verisure, sensor.android_ip_webcam, binary_sensor, lock.vera, api, alert, alarm_control_panel, ffmpeg, lock, frontend, config.group, switch, sensor.time_date, websocket_api, android_ip_webcam, sensor, media_player, discovery, http, mqtt, camera.generic, alarm_control_panel.manual, conversation, sun, sensor.openweathermap, sensor.template, sensor.speedtest, device_tracker, sensor.yr, history, media_player.cast, notify, light.rfxtrx, rfxtrx
17-04-09 19:43:44 WARNING (MainThread) [homeassistant.helpers.entity] Update for sensor.lamp_on_today is already in progress
Also this:
17-04-09 19:42:07 ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.rfxtrx]: Rfxtrx device 0a52091bbf0000e0240289_temperature is invalid: Invalid device id for OrderedDict([(‘0a52091bbf0000e0240289_temperature’, OrderedDict([(‘name’, ‘Utomhus’)])), (‘0a5202009e010036480379’, OrderedDict([(‘name’, ‘Krypgrunden’), (‘data_type’, [‘Humidity’, ‘Temperature’])])), (‘0a520201b30100c01a0269’, OrderedDict([(‘name’, ‘Källaren’), (‘data_type’, [‘Humidity’, ‘Temperature’])])), (‘0a520200ad010031240269’, OrderedDict([(‘name’, ‘Altan’), (‘data_type’, [‘Humidity’, ‘Temperature’])]))]) for dictionary value @ data[‘devices’]. Got OrderedDict([(‘0a52091bbf0000e0240289_temperature’, OrderedDict([(‘name’, ‘Utomhus’)])), (‘0a5202009e010036480379’, OrderedDict([(‘name’, ‘Krypgrunden’), (‘data_type’, [‘Humidity’, ‘Temperature’])])), (‘0a520201b30100c01a0269’, OrderedDict([(‘name’, ‘Källaren’), (‘data_type’, [‘Humidity’, ‘Temperature’])])), (‘0a520200ad010031240269’, OrderedDict([(‘name’, ‘Altan’), (‘data_type’, [‘Humidity’, ‘Temperature’])]))]). (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.rfxtrx/
17-04-09 19:42:17 WARNING (MainThread)
Also UNIFI stoped working, not a big problem but something i need to look at when this above is fixed.
Anyone haveing a idé?
