Hi Team,
My hassbian has been working a dream the last six months, I have been regularly updating etc. I just upgraded from 0.73.somethingorother to 0.74, and now it’s failing to load. The below is what my error log is showing.
Can anyone help or point me in the right direction? Any help would be hugely appreciated!
I am reluctant to remove chuanmi component as it’s running lights and sockets throughout the house!
2018-03-30 15:27:50 ERROR (MainThread) [homeassistant.loader] Unable to find component chuangmi
2018-03-30 15:27:50 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 179, in _step
result = coro.send(None)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/websocket_api.py", line 472, in get_services_helper
descriptions = await async_get_all_descriptions(self.hass)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 152, in async_get_all_descriptions
missing.add(domain_yaml_file(domain))
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 131, in domain_yaml_file
component_path = path.dirname(get_component(domain).__file__)
AttributeError: 'NoneType' object has no attribute '__file__'
2018-03-30 15:28:06 ERROR (SyncWorker_0) [homeassistant.components.light.yeelight] Failed to connect to bulb 10.39.167.111, yeelight_rgb_34ce008e9846: A socket error occurred when sending the command.
2018-03-30 15:28:20 ERROR (SyncWorker_18) [xiaomiplug.device] Unable to discover a device at address 10.39.167.102
2018-03-30 15:28:20 ERROR (SyncWorker_18) [custom_components.switch.xiaomiplug] Got exception while fetching the state: Unable to discover the device 10.39.167.102
2018-03-30 15:28:25 ERROR (SyncWorker_7) [xiaomiplug.device] Unable to discover a device at address 10.39.167.133
2018-03-30 15:28:25 ERROR (SyncWorker_7) [custom_components.switch.xiaomiplug] Got exception while fetching the state: Unable to discover the device 10.39.167.133
2018-03-30 15:28:51 ERROR (SyncWorker_17) [xiaomiplug.device] Unable to discover a device at address 10.39.167.102
2018-03-30 15:28:51 ERROR (SyncWorker_17) [custom_components.switch.xiaomiplug] Got exception while fetching the state: Unable to discover the device 10.39.167.102
2018-03-30 15:28:56 ERROR (SyncWorker_13) [xiaomiplug.device] Unable to discover a device at address 10.39.167.133
2018-03-30 15:28:56 ERROR (SyncWorker_13) [custom_components.switch.xiaomiplug] Got exception while fetching the state: Unable to discover the device 10.39.167.133
2018-03-30 15:29:00 ERROR (MainThread) [aiohttp.access] Error in logging
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/helpers.py", line 487, in __get__
return inst._cache[self.name]
KeyError: 'remote'
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/helpers.py", line 451, in log
for key, value in fmt_info:
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/helpers.py", line 443, in <genexpr>
for key, method in self._methods)
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/helpers.py", line 401, in _format_a
ip = request.remote
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/helpers.py", line 489, in __get__
val = self.wrapped(inst)
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_request.py", line 332, in remote
peername = self.transport.get_extra_info('peername')
File "/usr/local/lib/python3.6/asyncio/sslproto.py", line 306, in get_extra_info
return self._ssl_protocol._get_extra_info(name, default)
File "/usr/local/lib/python3.6/asyncio/sslproto.py", line 547, in _get_extra_info
return self._transport.get_extra_info(name, default)
AttributeError: 'NoneType' object has no attribute 'get_extra_info'
2018-03-30 15:29:22 ERROR (SyncWorker_19) [xiaomiplug.device] Unable to discover a device at address 10.39.167.102
2018-03-30 15:29:22 ERROR (SyncWorker_19) [custom_components.switch.xiaomiplug] Got exception while fetching the state: Unable to discover the device 10.39.167.102
2018-03-30 15:29:27 ERROR (SyncWorker_9) [xiaomiplug.device] Unable to discover a device at address 10.39.167.133
2018-03-30 15:29:27 ERROR (SyncWorker_9) [custom_components.switch.xiaomiplug] Got exception while fetching the state: Unable to discover the device 10.39.167.133
2018-03-30 15:29:51 ERROR (MainThread) [homeassistant.loader] Unable to find component chuangmi
2018-03-30 15:29:51 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2018-03-30 15:29:53 ERROR (SyncWorker_11) [xiaomiplug.device] Unable to discover a device at address 10.39.167.133
2018-03-30 15:29:53 ERROR (SyncWorker_11) [custom_components.switch.xiaomiplug] Got exception while fetching the state: Unable to discover the device 10.39.167.133
2018-03-30 15:29:58 ERROR (SyncWorker_17) [xiaomiplug.device] Unable to discover a device at address 10.39.167.102
2018-03-30 15:29:58 ERROR (SyncWorker_17) [custom_components.switch.xiaomiplug] Got exception while fetching the state: Unable to discover the device 10.39.167.102
2018-03-30 15:30:24 ERROR (SyncWorker_10) [xiaomiplug.device] Unable to discover a device at address 10.39.167.133
2018-03-30 15:30:24 ERROR (SyncWorker_10) [custom_components.switch.xiaomiplug] Got exception while fetching the state: Unable to discover the device 10.39.167.133
2018-03-30 15:30:30 ERROR (SyncWorker_9) [xiaomiplug.device] Unable to discover a device at address 10.39.167.102
2018-03-30 15:30:30 ERROR (SyncWorker_9) [custom_components.switch.xiaomiplug] Got exception while fetching the state: Unable to discover the device 10.39.167.102
2018-03-30 15:30:55 ERROR (SyncWorker_14) [xiaomiplug.device] Unable to discover a device at address 10.39.167.133
2018-03-30 15:30:55 ERROR (SyncWorker_14) [custom_components.switch.xiaomiplug] Got exception while fetching the state: Unable to discover the device 10.39.167.133
