Update to 10.3 yesterday .. today al least two crashes seen while I wanted to use EVCC (Addon)
I do not know if there is a connection or where to look for a helpful logfile info.
After my update to HA 10.3 there had been at lest 2 system crashes in the last 30min.
Saw that coz EVCC (installed as an addon) did not work anymore.
Restarting the addon did not work as well.
Restarting the whole HA System did help twice.
Besides some other “categories” within HA did not work then as well.
What should I do?
Thank you in advance!
Best regards
Sammy
The log files are stored in the config folder of HA, same folder as your configuration.yaml. Look for a file ending in log.1
Thanks … the following is to be found there:
2024-10-20 13:43:27.640 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration senec which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-20 13:43:27.641 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration homematicip_local which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-20 13:43:27.641 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration landroid_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-20 13:43:27.642 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration volkswagencarnet which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-20 13:43:27.643 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-20 13:43:27.643 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration waste_collection_schedule which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-20 13:43:27.644 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-20 13:43:27.645 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration home_connect_alt which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-20 13:43:27.646 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration dwains_dashboard which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-20 13:43:27.646 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration miele which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-20 13:43:31.311 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_verify_locations with args (<ssl.SSLContext object at 0x7f58a3ea8250>, '/usr/local/lib/python3.12/site-packages/certifi/cacert.pem', None, None) inside the event loop by custom integration 'alexa_media' at custom_components/alexa_media/__init__.py, line 341: AlexaLogin( (offender: /usr/local/lib/python3.12/ssl.py, line 708: context.load_verify_locations(cafile, capath, cadata)), please create a bug report at https://github.com/alandtse/alexa_media_player/issues
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#load_verify_locations
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
    exit_code = runner.run(runtime_conf)
  File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run
    return loop.run_until_complete(setup_and_run_hass(runtime_config))
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete
    self.run_forever()
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever
    self._run_once()
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once
    handle._run()
  File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
    self._context.run(self._callback, *self._args)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 165, in async_setup_component
    result = await _async_setup_component(hass, domain, config)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 461, in _async_setup_component
    await asyncio.gather(
  File "/usr/src/homeassistant/homeassistant/setup.py", line 463, in <genexpr>
    create_eager_task(
  File "/usr/src/homeassistant/homeassistant/util/async_.py", line 45, in create_eager_task
    return Task(coro, loop=loop, name=name, eager_start=True)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 742, in async_setup_locked
    await self.async_setup(hass, integration=integration)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 594, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/config/custom_components/alexa_media/__init__.py", line 341, in async_setup_entry
    AlexaLogin(
2024-10-20 13:43:31.387 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open with args (PosixPath('/config/.storage/[email protected]'),) inside the event loop by custom integration 'alexa_media' at custom_components/alexa_media/__init__.py, line 361: await login.login(cookies=await login.load_cookie()) (offender: /usr/local/lib/python3.12/site-packages/aiohttp/cookiejar.py, line 126: with file_path.open(mode="rb") as f:), please create a bug report at https://github.com/alandtse/alexa_media_player/issues
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#open
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
  File "/config/custom_components/alexa_media/__init__.py", line 361, in async_setup_entry
2024-10-20 13:43:33.790 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open with args (PosixPath('/config/.storage/[email protected]'),) inside the event loop by custom integration 'alexa_media' at custom_components/alexa_media/__init__.py, line 361: await login.login(cookies=await login.load_cookie()) (offender: /usr/local/lib/python3.12/site-packages/aiohttp/cookiejar.py, line 121: with file_path.open(mode="wb") as f:), please create a bug report at https://github.com/alandtse/alexa_media_player/issues
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
2024-10-20 13:43:33.800 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_verify_locations with args (<ssl.SSLContext object at 0x7f589fa1dcd0>,) inside the event loop by custom integration 'alexa_media' at custom_components/alexa_media/__init__.py, line 922: http2 = HTTP2EchoClient( (offender: /usr/local/lib/python3.12/site-packages/httpx/_config.py, line 149: context.load_verify_locations(cafile=cafile)), please create a bug report at https://github.com/alandtse/alexa_media_player/issues
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
  File "/config/custom_components/alexa_media/__init__.py", line 363, in async_setup_entry
    await setup_alexa(hass, config_entry, login)
  File "/config/custom_components/alexa_media/__init__.py", line 1312, in setup_alexa
    await http2_connect()
  File "/config/custom_components/alexa_media/__init__.py", line 922, in http2_connect
2024-10-20 13:43:38.582 ERROR (MainThread) [aiohttp_sse_client.client] fetch https://api.home-connect.com/api/homeappliances/events failed: 503
2024-10-20 13:43:42.595 ERROR (MainThread) [aiohttp_sse_client.client] fetch https://api.home-connect.com/api/homeappliances/events failed: 503
2024-10-20 13:43:50.609 ERROR (MainThread) [aiohttp_sse_client.client] fetch https://api.home-connect.com/api/homeappliances/events failed: 503
2024-10-20 13:44:06.668 ERROR (MainThread) [aiohttp_sse_client.client] fetch https://api.home-connect.com/api/homeappliances/events failed: 503
2024-10-20 13:44:27.298 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:44:38.734 ERROR (MainThread) [aiohttp_sse_client.client] fetch https://api.home-connect.com/api/homeappliances/events failed: 503
2024-10-20 13:44:39.030 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:45:30.560 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:45:42.799 ERROR (MainThread) [aiohttp_sse_client.client] fetch https://api.home-connect.com/api/homeappliances/events failed: 503
2024-10-20 13:45:43.215 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:47:07.631 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:47:17.430 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:47:42.863 ERROR (MainThread) [aiohttp_sse_client.client] fetch https://api.home-connect.com/api/homeappliances/events failed: 503
2024-10-20 13:48:08.881 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:48:21.623 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:49:13.231 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:49:25.792 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:49:42.928 ERROR (MainThread) [aiohttp_sse_client.client] fetch https://api.home-connect.com/api/homeappliances/events failed: 503
2024-10-20 13:50:17.537 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:50:29.985 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:51:21.782 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:51:21.856 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:52:23.607 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:52:28.082 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:53:29.302 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:53:37.789 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:54:35.523 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:54:41.913 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:55:36.742 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:55:46.121 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:56:36.239 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:56:37.969 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:57:39.190 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:58:39.439 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 13:58:44.232 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:59:36.055 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 13:59:40.670 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 14:00:36.891 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 14:01:40.156 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 14:01:44.209 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 14:02:37.317 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 14:02:37.320 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 14:03:43.584 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 14:04:44.239 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 14:04:44.803 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 14:05:37.719 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 14:05:41.015 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 14:06:17.828 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 14:06:27.222 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 14:06:28.710 ERROR (MainThread) [custom_components.miele] Timeout fetching miele data
2024-10-20 14:06:42.954 ERROR (MainThread) [homeassistant.components.bring.coordinator] Error fetching bring data: Unable to connect and retrieve data from bring
2024-10-20 14:07:13.426 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 14:07:22.050 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 14:08:05.416 WARNING (MainThread) [pymiele.pymiele] Ping timeout, closing connection and restarting
2024-10-20 14:08:13.879 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
2024-10-20 14:08:19.650 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 14:08:57.830 WARNING (MainThread) [volkswagencarnet.vw_connection] Could not fetch selectivestatus, error: Cannot connect to host emea.bff.cariad.digital:443 ssl:default [None]
2024-10-20 14:08:57.831 WARNING (MainThread) [volkswagencarnet.vw_connection] Could not fetch vehicle data, error: Cannot connect to host emea.bff.cariad.digital:443 ssl:default [None]
2024-10-20 14:08:57.832 WARNING (MainThread) [volkswagencarnet.vw_connection] Could not fetch parkingposition, error: Cannot connect to host emea.bff.cariad.digital:443 ssl:default [None]
2024-10-20 14:09:04.053 WARNING (MainThread) [custom_components.senec.pysenec_ha] APP-API: NO RES - Could not get data from https://app-gateway.prod.senec.dev/v2/senec/systems/239062/dashboard causing: Cannot connect to host app-gateway.prod.senec.dev:443 ssl:False [None]
2024-10-20 14:09:15.866 WARNING (MainThread) [homeassistant.components.androidtv_remote] Disconnected from TV at 192.168.178.53
2024-10-20 14:09:28.063 WARNING (MainThread) [custom_components.senec.pysenec_ha] APP-API: NO RES - Could not get data from https://app-gateway.prod.senec.dev/v1/senec/monitor/239062/data/custom?startDate=2018-01-01&endDate=2024-11-01&locale=de_DE&timezone=GMT causing: Cannot connect to host app-gateway.prod.senec.dev:443 ssl:False [None]
2024-10-20 14:09:52.071 WARNING (MainThread) [custom_components.senec.pysenec_ha] APP-API: NO RES - Could not get data from https://app-gateway.prod.senec.dev/v1/senec/systems/239062/technical-data causing: Cannot connect to host app-gateway.prod.senec.dev:443 ssl:False [None]
2024-10-20 14:10:10.713 ERROR (MainThread) [aiohttp_sse_client.client] fetch https://api.home-connect.com/api/homeappliances/events failed: 503
2024-10-20 14:10:18.551 ERROR (Thread-7) [pychromecast.socket_client] [TV(192.168.178.53):8009] Error reading from socket: socket connection broken
