All,
I am getting started with Hass.io, first sonoff´s reflashed and up and running through MQTT. With this forum being of great help, browsing through earlier posts.
I am now stuck with the following, when selecting “Update” in supervisor dashboard, I get an error. With the below message in the log.
**20-03-23 12:49:44 ERROR (SyncWorker_13) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:0.107.5 -> 500 Server Error: Internal Server Error ("Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on [::1]:53: read udp [::1]:54959->[::1]:53: read: connection refused").**
**20-03-23 12:49:44 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails**
What did I miss ? Configuration of somethign somewhere ?
Appreciate your help, grtz
John
Hey same issue for me, update from 0.106.6 to 0.107.5 fails with same error message
20-03-23 19:41:23 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.107.5
20-03-23 19:41:23 INFO (SyncWorker_0) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.106.6 to homeassistant/qemux86-64-homeassistant:0.107.5
20-03-23 19:41:23 INFO (SyncWorker_0) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.107.5.
20-03-23 19:41:33 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.107.5 -> 404 Client Error: Not Found ("no such image: homeassistant/qemux86-64-homeassistant:0.107.5: No such image: homeassistant/qemux86-64-homeassistant:0.107.5").
20-03-23 19:41:33 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
Check the connection to internet, if it jumps for a second, stop automatically the uploading.
In any case, is better upload HA from the CLI with the command “ha core update”, so you can check the status live
Thanks @magik95 - Tried the CLI, but same result (seems our UI is just a frontend to to the CLI commands). My internet connection is superstable, and un-interrupted.
@Dario_Musante Seems your error points in a different direction then my failure ( your “No Such Image” tells me the image for download is not there or at a different location)
When I dig into the error message I get, it feels like I am having a problem with “authority”, as the heart of the matter is a “Connection Refused”. See log extract below. Any guidance or pointing me in the right direction much appreciated !
'20-03-24 08:49:19 ERROR (SyncWorker_12) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi4-64-homeassistant:0.107.5 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on [::1]:53: read udp [::1]:37117->[::1]:53: read: connection refused”). ’
The Home-assistant data base is realy too big !
I delete it :
sudo rm home-assistant_v2.db
Don’t worry ! Home-assistant will recreate it automatically, but beware ! you lose all stored data
Now, there is enough space to update Hassio to 0.107.5
[EDIT]
for more information: Hassio is installed on a VirtualBox VM with 1 GB of ram but only 6 GB of disk, which is insufficient
All,
SOLVED (the “connection refused” issue) :
Since my system is still in early stage of setting it up, I decided to go for a fresh install (0.107.6). All went well, and then I noticed that the system log of the maiden installation (the 20 minutes waiting phase) showed two similar events when trying to load packages. The maiden installation then logged a “retry in 30 seconds”, and that load passed after 2nd retry. So far so good. Core 0.107.6 installed and up and running.
I just now noticed there was an update to 0.107.7 available. Using the UI to update, same error message came up. But after waiting for a moment and just retrying, the update simply came through without errors.
So my advice is to just wait and retry a couple of times. It has nothing to do with wrong settings or alike, maybe that central server is too busy or too many parallel connections and then refuses a new connection.
