Got a working docker image currently on 2021.1.5 but updating to 2021.2.x fails to load the web interface. Looks like it got something to do with the SSL certs, I used this guide to set it up (only difference being the homeassistant
user didnt exist, so I used root).
Any ideas on what the issue is? Thanks
Docker logs below:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
[s6-init] ensuring user provided files have correct perms...exited 0.,
[fix-attrs.d] applying ownership & permissions fixes...,
[fix-attrs.d] done.,
[cont-init.d] executing container initialization scripts...,
[cont-init.d] udev.sh: executing... ,
[12:26:15] INFO: Setup udev backend inside container,
starting version 3.2.9,
[12:26:15] INFO: Update udev information,
[cont-init.d] udev.sh: exited 0.,
[cont-init.d] done.,
[services.d] starting services,
[services.d] done.,
2021-02-22 12:26:20 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hive which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.,
2021-02-22 12:26:20 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.,
2021-02-22 12:26:21 WARNING (MainThread) [homeassistant.components.http] The 'base_url' option is deprecated, please remove it from your configuration,
2021-02-22 12:26:21 ERROR (MainThread) [homeassistant.config] Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/root/dehydrated/certs/xxxxx.duckdns.org/fullchain.pem',
not a file for dictionary value @ data['http']['ssl_key']. Got '/root/dehydrated/certs/xxxxx.duckdns.org/privkey.pem'. (See /config/configuration.yaml, line 20). Please check the docs at https://www.home-assistant.io/integrations/http,
2021-02-22 12:26:21 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Invalid config.,
2021-02-22 12:26:21 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_log. Setup failed for dependencies: http,
2021-02-22 12:26:21 ERROR (MainThread) [homeassistant.setup] Setup failed for system_log: Could not set up all dependencies.,
2021-02-22 12:26:22 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=41 from 2021-02-22 11:37:05.179175),
2021-02-22 12:26:22 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of config. Setup failed for dependencies: http,
2021-02-22 12:26:22 ERROR (MainThread) [homeassistant.setup] Setup failed for config: Could not set up all dependencies.,
2021-02-22 12:26:22 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of alexa. Setup failed for dependencies: http,
2021-02-22 12:26:22 ERROR (MainThread) [homeassistant.setup] Setup failed for alexa: Could not set up all dependencies.,
2021-02-22 12:26:22 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of websocket_api. Setup failed for dependencies: http,
2021-02-22 12:26:22 ERROR (MainThread) [homeassistant.setup] Setup failed for websocket_api: Could not set up all dependencies.,
2021-02-22 12:26:22 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of webhook. Setup failed for dependencies: http,
2021-02-22 12:26:22 ERROR (MainThread) [homeassistant.setup] Setup failed for webhook: Could not set up all dependencies.,
