Karle
(Karle)
1
Hi All,
I updated from 2024.12 to 2025.01 today. In the past I never had any issues with HA, but today after the update i had several issues:
- all measurement units like °C, kWh, … were gone
- my dewpoint calculation did not work for my lacrosse sensors (although the sensors worked)
- my history of the entities did not show up
- my diagrams in the UI also did not show up
Has someone an idea what could be the root cause of this problems ? Did I miss something necessary for the update ?
At the moment I went back to 2024.12 → everything is fine again.
Greets Karl
Dujith
(Charles Evers)
2
Without any logs or error messages and without knowing what integrations you are running its gonna be a shot in the dark.
Karle
(Karle)
3
I had no error message popping (normally it does when something does not work), but i did not check the log.
So I will wait for 2025.02 and test again.
I use nearly 30 integrations … the error on the froinus will be gone tomorrow morning when the inverter is back online.
With the december version it is working.
Has there been any update in the background of the database or something with the new release ?
tom_l
4
Yes but it has not caused any issues.
We need those logs to help you.
jchh
((not John))
5
Clear your front end cache?
Karle
(Karle)
6
I will try again with the next Version coming Out.
If this makes Problems i will Check and Post the logs.
Karl
