Same here, just upgraded to 0.57.2 from 0.57.1, and getting “500 Internal Server Error”.
No change to the configuration. Also tried to reboot the RPi2.
This is the trace in the log:
Nov 11 13:19:18 hassbian hass[601]: — Logging error —
Nov 11 13:19:18 hassbian hass[601]: Traceback (most recent call last):
Nov 11 13:19:18 hassbian hass[601]: File “/usr/lib/python3.4/logging/init.py”, line 978, in emit
Nov 11 13:19:18 hassbian hass[601]: msg = self.format(record)
Nov 11 13:19:18 hassbian hass[601]: File “/usr/lib/python3.4/logging/init.py”, line 828, in format
Nov 11 13:19:18 hassbian hass[601]: return fmt.format(record)
Nov 11 13:19:18 hassbian hass[601]: File “/usr/lib/python3.4/logging/init.py”, line 573, in format
Nov 11 13:19:18 hassbian hass[601]: record.exc_text = self.formatException(record.exc_info)
Nov 11 13:19:18 hassbian hass[601]: File “/usr/lib/python3.4/logging/init.py”, line 523, in formatException
Nov 11 13:19:18 hassbian hass[601]: traceback.print_exception(ei[0], ei[1], tb, None, sio)
Nov 11 13:19:18 hassbian hass[601]: File “/usr/lib/python3.4/traceback.py”, line 169, in print_exception
Nov 11 13:19:18 hassbian hass[601]: for line in _format_exception_iter(etype, value, tb, limit, chain):
Nov 11 13:19:18 hassbian hass[601]: File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter
Nov 11 13:19:18 hassbian hass[601]: for value, tb in values:
Nov 11 13:19:18 hassbian hass[601]: File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain
Nov 11 13:19:18 hassbian hass[601]: context = exc.context
Nov 11 13:19:18 hassbian hass[601]: AttributeError: ‘NoneType’ object has no attribute ‘context’
Nov 11 13:19:18 hassbian hass[601]: Call stack:
Nov 11 13:19:18 hassbian hass[601]: File “/srv/homeassistant/bin/hass”, line 11, in
Nov 11 13:19:18 hassbian hass[601]: sys.exit(main())
Nov 11 13:19:18 hassbian hass[601]: File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/main.py”, line 366, in main
Nov 11 13:19:18 hassbian hass[601]: exit_code = setup_and_run_hass(config_dir, args)
Nov 11 13:19:18 hassbian hass[601]: File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/main.py”, line 293, in setup_and_run_hass
Nov 11 13:19:18 hassbian hass[601]: return hass.start()
Nov 11 13:19:18 hassbian hass[601]: File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/core.py”, line 158, in start
Nov 11 13:19:18 hassbian hass[601]: self.loop.run_forever()
Nov 11 13:19:18 hassbian hass[601]: File “/usr/lib/python3.4/asyncio/base_events.py”, line 244, in run_forever
Nov 11 13:19:18 hassbian hass[601]: self._run_once()
Nov 11 13:19:18 hassbian hass[601]: File “/usr/lib/python3.4/asyncio/base_events.py”, line 1081, in _run_once
Nov 11 13:19:18 hassbian hass[601]: handle._run()
Nov 11 13:19:18 hassbian hass[601]: File “/usr/lib/python3.4/asyncio/events.py”, line 120, in _run
Nov 11 13:19:18 hassbian hass[601]: self._callback(*self._args)
Nov 11 13:19:18 hassbian hass[601]: File “/usr/lib/python3.4/asyncio/tasks.py”, line 237, in _step
Nov 11 13:19:18 hassbian hass[601]: result = next(coro)
Nov 11 13:19:18 hassbian hass[601]: File “/srv/homeassistant/lib/python3.4/site-packages/aiohttp/web_protocol.py”, line 557, in handle_parse_error
Nov 11 13:19:18 hassbian hass[601]: resp = self.handle_error(request, status, exc, message)
Nov 11 13:19:18 hassbian hass[601]: File “/srv/homeassistant/lib/python3.4/site-packages/aiohttp/web_protocol.py”, line 522, in handle_error
Nov 11 13:19:18 hassbian hass[601]: self.log_exception(“Error handling request”, exc_info=exc)
Nov 11 13:19:18 hassbian hass[601]: File “/srv/homeassistant/lib/python3.4/site-packages/aiohttp/web_protocol.py”, line 362, in log_exception
Nov 11 13:19:18 hassbian hass[601]: self.logger.exception(*args, **kw)
Nov 11 13:19:18 hassbian hass[601]: Message: ‘Error handling request’
Nov 11 13:19:18 hassbian hass[601]: Arguments: ()
