update 3:
cheered too soon… took only 2 reboots to kill Hassio again, without even changing anything in the files, other than updating 2 add-on’s in the Hassio system…
#bangingheadagainstthewall
update 2:
lo and behold, ive got Hassio!
in a desperate attempt to comment out extra settings in the configuration.yaml, I commented out weather:
pointing the a weather.yaml file with contents:
#- platform: openweathermap
# api_key: !secret openweather_key
- platform: yweather
#- platform: yweather
# name: Weer
#- platform: buienradar
# name: !secret buienradar_station
This worked just fine for the only left yweather component , which in itself was customized via the
- /local/custom_ui/custom-weather-card.html
tis custom card was the best of the weather cards sofar, even better than the new weather card in Hassio…
maybe theres a setting in that configuration blocking Hassio, and still allowing the card to be configured. Further investigating is to be done…
anyways, for completeness sake here’s he relevant bit of the log:
2018-05-21 00:38:23 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:38:26 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:38:29 INFO (MainThread) [homeassistant.setup] Setting up hassio
2018-05-21 00:38:30 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:38:33 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:38:37 ERROR (MainThread) [homeassistant.components.light.hue] Unable to reach bridge 192.168.1.212
2018-05-21 00:38:39 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:38:40 WARNING (MainThread) [homeassistant.setup] Setup of hassio is taking over 10 seconds.
2018-05-21 00:38:45 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:38:50 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:38:54 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-05-21 00:38:55 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:38:59 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:39:01 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 31.4 seconds.
2018-05-21 00:39:02 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:39:05 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:39:08 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:39:16 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:39:19 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-21 00:39:24 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
update 1:
having checked and rechecked the full setup, disabled most anything, and reorganized into packages for easy en/disabling parts, I still cant get Hassio to initiate. Separated it from the Hue issues that also still are there, ive disabled that now completely, and have this a the end of the startup:
2018-05-20 23:33:10 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-20 23:33:13 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-20 23:33:18 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-20 23:33:21 INFO (MainThread) [homeassistant.setup] Setting up hassio
2018-05-20 23:33:22 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-20 23:33:24 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-20 23:33:26 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-20 23:33:29 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-20 23:33:31 WARNING (MainThread) [homeassistant.setup] Setup of hassio is taking over 10 seconds.
2018-05-20 23:33:32 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/ping request
2018-05-20 23:33:32 ERROR (MainThread) [homeassistant.components.hassio] Not connected with Hass.io
2018-05-20 23:33:32 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 11.1 seconds.
2018-05-20 23:33:32 ERROR (MainThread) [homeassistant.setup] Setup failed for hassio: Component failed to initialize.
2018-05-20 23:33:35 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-20 23:33:42 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-20 23:33:45 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-20 23:33:48 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-20 23:33:50 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-05-20 23:33:50 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
Im completely out of ideas what to do, or how to proceed investigating the error. Any thoughts would be appreciated…
Btw, other than the Hue problems, my full setup seems to work just fine, except for exactly 1 automation at startup. I take it this stems from the timer out of sync error, since when i run the automation manually it works just as it should.
again, all this started after upgrading to .69 and .69.1 before which Hue was implemented differently, and worked beautifully…
this is the automation:
# Startup
- alias: 'Opstart'
initial_state: 'on'
platform: homeassistant
event: start
condition: []
- delay: 00:00:03
- service: homeassistant.turn_on
entity_id: script.opstart
- delay: 00:00:03
entity_id: script.mode_normal
- delay: 00:00:02
- service: notify.notify
message: Startup went fine.
- delay: 00:00:02
- condition: state
entity_id: input_boolean.notify_notify
state: 'on'
- service: notify.marijn
data_template:
message: 'HomeAssistant is back up and running since
{{ as_timestamp(now()) | timestamp_custom("%d %b %X") }} and it is
{{ states.sensor.rsd_temperature.state}} degrees.'
push:
sound: "US-EN-Morgan-Freeman-Welcome-Home.wav"
I do get to see the message: Startup went fine, and the notify.marijn is done, but the intermediate scripts aren’t run, and the push:sound isnt executed either.
