Like the titles says, I have no ZigBee connections from Home assistant or switches to control lights, but on Zigbee2mqtt expose tab I can turn on and off the lights. There’s no info on the logs. If I reboot, everything works fine for a couple of minutes and the problem reappears.
I have two seperate HA setups with zigbee2mqtt, they have worked perfectly until yesterday they both stopped working, I have no connection and can not toggle any lights or get any reading from temp and humidity sensors. They stopped working 2022-10-19 the same day with 12 difference.
Restart does not help and running all latest updates.
Exactly the same here. I had to revert to a previous backup and everything worked perfectly.
