so far all upgrades on my Odroid M1 have been fantastic and all functionality of HA has made me very happy. So, today, when I saw the new HAOS 11 update, I thought I’d install it. Unfortunately, that was the last I saw from my HA. I got stuck on " Waiting for the Homeassistant CLI to be ready" and did not proceed for over 2 hours. I could not turn off some of the lights…
I need re-installation from backup, but apparently that is a partial back-up…and I cannot tell from the name of the backup what it is for. The only way to find out what it is is to go through the tar files. I guess the biggest one is the starting point. How can I restore everything (especially my zigbee)?
Same issue here - Odroid M-1 and never had any problems till this update. After waiting 9 hours, I did a new install on 11.0 on my SD acrd which loaded fine. Then I did a restore form back-up and that took all night but eventually came back to life. Then I moved my data disk to the NVMe M.2 Internal SSD where itt was originally and its been 8 hours and has not come back to life.
Update: Gave up with 11.0, downloaded 10.5 and did a restore. Took aboit an hour to restore and get evrything back Two days wasted with 11.00.
I’ve unfortunately run into the same problem after upgrading my ODROID M1. Relabelling the data partition to hassos-data (from hassos-data-dis) did move Home Assistant closer to starting, with the observer container successfully starting. Unfortunately, that’s where it seems to stall and I’m not too sure how to move forward from here.
Rebooting the system results in the label being reset to hassos-data-dis, which once again causes HA to fail loading.
Does anyone have an idea how to move forward without starting over and restoring a backup?
Thanks to Victorsueca’s help on the GitHub issue, I was able to get HA booted into 11.0. The issue will come back on reboot but at least there is a way to get it up and running again until a permanent fix is available.
On boot/reboot and once you’ve gained access to the system console (Ctrl + Alt + F2), run the following command to correctly label the disk partition:
e2label /dev/nvme0n1p1 hassos-data
Wait a few seconds and then start the supervisor service:
11.1 version is out and the problem is fixed.
If you have broken install, remove “-dis” from the label name, mount it, install 11.1, reboot and everything will be fine.
