Python 3.8 is now supported, so you should build a new venv with that (Python 3.8.3) to give yourself a longer time before you have to do this again. I’ve explained the process here.
Thx that’s the solution, HA still was using python 3.6 since I had forgotten to switch the system default after installing python 3.8: update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.8 5
after this and reinstall of homeassistant the actual version is running now
