Update value of a platform: intergration
Hi All,
I have created some integrations like below:
- platform: integration
  source: sensor.dishwasher_watt
  name: "Total dishwasher kWh"
  unit_prefix: k
  round: 2
This because my Neo Coolcam kHw values goes into negative when restart HA.
How can I update the intergration value?
Now it shows 1,8 kWh. But in real since I use the neo cool cam wall switches the usage is already 208,88 kWh. I want update the intergration so it have the correct usage.
In the
core.restore.state
I see the sensor and the value. Can I stop HA change this value and start HA again? (HAOS 6.6)
If you feed the energy sensor to a utility meter there are calibration and reset services available (if you set at least one tariff).
https://www.home-assistant.io/integrations/utility_meter/#services
Thanks.
I stopped the docker oh homeassistant and updated the core.restore file.
Start docker homeassistant and the values are ok now :slight_smile:
