According to the notes I took, I downloaded the firmware file(s) to the tmp folder on my home-assistant, then ran the docker cp command in the console: # docker cp /tmp/hue.sbl-ota addon_core_deconz:/data/otau/
The file is then available to deconz and you can use it for updating your hue bulbs
If you used ā# docker cp ā¦ā then the ā#ā acts as a comment and nothing is executed. Just remove the "# " before the ādocker cpā and it should work (provided that the other paths are correct)
omg! @azee, thank you so much.
This is such a pain in the assā¦ Iāve been trying for hours.
I love the old webapp 1000x more than the new sluggish white design-thingy.
The box via the old web app was not ticket at my instance.
But still, after that, until now no updates have started, just one is āqueuedā - Iām waiting.
Do you need to deactivate the old webapp after setting that tick?
Thank you, mate!
Got the OTA updater working by following the instructions here.
I got quite some deconz devices so did some this evening, stopped the process because all the lights that I have updated now randomly turn off and on at an interval of about 5min. So they work fine, can change all the properties but when they are ON they just go OFF after about 5min and back ON after 2/3 seconds.
The following is in the deconz log about that device ID:
23:48:30:953 DeviceAnnce of LightNode: 0xec1bbdfffe2111fe Permit Join: 0
23:48:31:237 ZCL got data for node=0xCBC6, cl=0x0006, at=0x0000, status=0x00, type=0x10
23:48:31:390 ZCL attribute report 0xEC1BBDFFFE2111FE for cluster: 0x0300, ep: 0x01, frame control: 0x08, mfcode: 0x0000
Have you, or anybody else, found a solution for this? Its taking forever to update all devicesā¦
is it somehow possible to query all so theyāre like in a queue?
Hi, on my side, no. I donāt have a developer background. I somewhat āgave upā on updates as itās not sustainable. And honestly, itās a horrendous user interface. Thereās no search, no filtering and nothing intuitive. So as long as devices workā¦ Thatās it. And when they stop (Iāve got a couple that are 4-5 years old), id rather buy new ones than try to figure out which one to update and remember how II once didā¦)
Thatās sad but for me, this is a development platform, not an end user management interface.
Sorry for not helping much.
Edit: thinking about this, Iām curious if other ZigBee gateways might nowadays be a better choice than Deconzā¦
Iād consider moving away from using Deconz as the software layer.
I canāt say ZHA is much easier, but Iāve heard good things about Z2M that keeps a repository of .ota files that come from other vendors than Tradfri.
Does anyone know whether activating OTAU on my ODROID (Hass Blue) will just re-upgrade and overwrite the v3.4 firmware? Also, where are people putting their firmware so that they can find it from inside Deconz?
hey all,
sorry, very confused and need some help please!
RPI4
Home Assistant 2022.2.2
Home Assistant OS
Deconz: Current version: 6.11.1
Conbee2 stick connected to RPI4 via USB
i can connect via HA Deconz addon and via VNC.
Im trying to update various devices, however how do i run the ikea script?
i cant seem to upload files and not sure where to save things to then move them over?
sorry, ive read various items but cant work it out.
Ok No response to my above question to remove old fw zigbee filesā¦
But now I just started to upgrade my IKEA Zigbee repeaters but it seems like it runs the same update over and over again - after 100% it runs again and the version number stays the same?
Steps worked for me to access the old interface (although Iām still unable to passe the Queue state of the firmware updateā¦)
Therefore my Ikea Tradfri Shortcut button remains to 2.3.015 instead of upgrading to 2.3.080
Just a quick correction : credentials for the old interface are :
Username : delight
Password : [your Phoscon pwd]
(My config: RPi4, Hassio, Conbee II stick, deConz)
I found that you can wait forever for an Ikea device to wake up and start the upgrade. My solution was to first queue the OTAR from Deconz and then remove the battery and put it back. Then usually within a minute or two the OTAR starts. And it can take 30-60 minutes and only one device at a time
Got it!
You have to use āSSH & Web Terminal add-onā and not āTerminal & SSHā.
On the first one, the docker command is available and you can copy the files.
