i have one issue with the ac entities, i want to also when the ac off to be like the other buttons, all other states “cool”,“heat”,“on”, that it will highlighted like the other.
i don’t know how to it, here is the ac code below:
@AmoebeLabs I’ve managed to get your theme working with the decluttering template but I was wondering how you can have the template as a separate file that you include. You seem to have it that way as it is a separate file in your repo. Right now I have the decluttering template written using raw config editor right under the resources section. The raw config editor does not seem to accept the tradition !include
But as @jimz011 already mentioned, if you want to use decluttering templates, re-use of components and more advanced settings, the yaml mode is the way to go.
The config editor can’t handle includes and also can’t reuse views/cards.
I wouldn’t want to go back to the config editor, as it limits my configuration enormously and gives me maintenance problems as it is one big file.
Thanks @jimz011 and @AmoebeLabs
I do the majority of my UI in raw config editor and not the UI editor so I don’t have a problem switching to YAML mode. Once I’m there, I’m assuming includes work like they do in configuration.yaml because the ui is just another yaml file right?
Yes I will do that in the upcoming days. A bit busy right now
Yes, I define everything, if possible in the themes. So YES, wallpapers are part of the theme…
He Jim. That is great to hear. Is it only theming or also some things in the decluttering templates and cards?
That is the way to go. Sharing == learning, new idea’s and valuable feedback. I will probably visit your github repo again to see how you solved certain problems or views.
Acknowledging the work of others is also another way to go. Nothing wrong with re-using code, idea’s and solutions with a reference to the source. Thanks!.
Breek me de bek niet open
I’m trying to finish a new card, and since it is very flexible, it takes a lot, and I mean a lot of effort to write the documentation. The card can handle multiple entities and attributes in a flexible definable layout with additional things like circles, lines, icons and text. On top of that, you can add animations depending on the state change of an entity (like colors and real animations).
Exactly. Anyways I haven’t copied your decluttering card no. I still use the same as I have always used (it works fine and changing too much, which I already have for my upcoming update makes updating very difficult for the masses and I know a lot of people actually use my config). In that way I have tried to change as less as possible in both your theme file as in my decluttering cards (which seems to have worked out very well for at least the light theme). Yes I have changed some colors to reflect the colors I already have better with your theme and I had to make adjustments to the primary color as that is the color the header gets in iOS (and unfortunately up until now I havent found a great solution to this. If only the iOS Header could be split from the primary color, but well we have to work with what we have).
Actually I have multiple reasons why I do not want to change too much in the themes. As you post them on github and other people use them they can use it with my configuration with only minimal changes. It is around 8 lines that I have changes and most changes revolve around that damn header. I am still trying to recreate my dark theme in your style (which took me a bit more changes).
Acknowledging other peoples work is indeed a great thing and greatness comes from little things.
I honestly like the themes you create even though the dark theme is not in the colors I use in my config. But your themes are definitely one of the better ones around here!
What header in iOS? You mean in the below picture the wheat background with black/dark grey font?
Or are you referring to something completely different??
I actually said it wrong, I meant the status bar in iOS (the one at the top which has the time in it and wifi status).
The bar will only color with a primary color, in any other case it will stay black. Or I will have to create a blank theme with only primary color black. Have it start with HA and then change theme manually in the profile menu as the status bar only changes color when doing an actual service-call.
Not ideal as you can see. It is only apparent on iPhones/iPads and most notably the ones with a notch.
Completely off-topic, but how do you get the temperatures of your fridge and freezer? Did you just stick a temperature sensor inside of them or some other way?
I don’t know if I’m missing something, but where can I download the Teal theme from?
The GitHub repository just seems to have the readme file and screenshots, but no theme files.
I’m liking these themes, but I had a problem with the dialogues having transparent background and making them difficult to read. The more-info dialogue title bar also looks like white text on a slightly off-white background
And here is an example (using the orange Nyx theme):
I’ve got it working for me by making these changes to the theme locally (the more-info dialogue appears to use secondary-background-color as the background colour of the title bar):
(I got the hex colour for the dialogue background by taking a screenshot of a more-info popup, opening it in an image editor, and using the colour picker tool to find the colour)
A yes, that is caused by official material design rules where you use an opaque color to elevate the foreground from the background. But that doesn’t work for popup’s of course. Google forgot to mention that in their documentation
I want to update all the themes, and will take this fix into the next release, so the dialog background isn’t opaque anymore but the pure color it is meant to be, which seems to be #313131
I will tag the current version with 1.0 and the updated theme to 1.1.
