solmoller
(Henrik Møller Jørgensen)
1
Energinet is changing their API on September 1st 2022
New rest interface, that has same output as old is here:
- platform: rest
scan_interval: 600
resource: https://api.energidataservice.dk/dataset/elspotprices?limit=120&filter{%22PriceArea%22:%22DK1%22}&sort=HourDK%20desc
value_template: 'OK'
unit_of_measurement: "DKK"
json_attributes:
- records
solmoller
2
To be used with ApexCharts card
zamzon
(Mads)
3
Could you show how to set it up with an ApexCharts card?
If you rather would like the HACS approach, then it’s already there. MTrab/energidataservice: Fetches spot prices from Energi Data Service (github.com)
And in the wiki is an example for Apex Charts.
cant see “Energidataaservice” in Home Assistant > Settings > Integrations even after restart and CTRL+F5?
The plugin is installed using HACS
BlackChart
(Malene Trab)
7
If it’s installed correctly, you should see something along this:![image](https://community-assets.home-assistant.io/original/4X/4/1/7/417e317d9a6ea9f10082b685e45a6f5b9343fab0.png)
