I am running the homeassistant docker in Unraid. Yesterday there was an update and it processed without issue, but I was alerted by my wife that the lights were acting funny. I logged in to HA and sure enough, 80% of my zwave network is now showing up as “Node:Undefined Undefined”. For these nodes, there are no entities associated with them with the zwave manager. I checked the entitty manager and it stills sees the zwave devices as well as the entities, but they are all marked as “unavailable”.
I’ve tried restarting the app and zwave multiple times but this has not resolved the issue. I’ve attempted a network heal and again, no changes. Tested the network and again, no changes.
When rebooting the log clearly shows all the impacted nodes as timing out
2020-03-23 21:45:06 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 67 not ready after 30 seconds, continuing anyway
2020-03-23 21:45:06 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 68 not ready after 30 seconds, continuing anyway
2020-03-23 21:45:06 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 69 not ready after 30 seconds, continuing anyway
2020-03-23 21:45:06 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 70 not ready after 30 seconds, continuing anyway
many of the devices are even still calling back to Home Assistant, but it seems confused. For example, here is the power switch/meter on my coffee pot:
2020-03-24 07:09:51.241 Info, Node062, ApplicationCommandHandler - Unhandled Command Class 0x32
2020-03-24 07:10:20.942 Detail, Node062, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x3e, 0x0a, 0x32, 0x02, 0x21, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xba
2020-03-24 07:10:20.942 Info, Node062, ApplicationCommandHandler - Unhandled Command Class 0x32
2020-03-24 07:10:50.942 Detail, Node062, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x3e, 0x0a, 0x32, 0x02, 0xa1, 0x64, 0x00, 0x01, 0xe6, 0x0b, 0x00, 0x00, 0xc6
2020-03-24 07:10:50.942 Info, Node062, ApplicationCommandHandler - Unhandled Command Class 0x32
2020-03-24 07:10:51.041 Detail, Node062, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x3e, 0x0a, 0x32, 0x02, 0xa1, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x22
2020-03-24 07:10:51.041 Info, Node062, ApplicationCommandHandler - Unhandled Command Class 0x32
2020-03-24 07:10:51.144 Detail, Node062, Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x3e, 0x0e, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x66, 0x38, 0x00, 0x3c, 0x00, 0x00, 0x66, 0x38, 0x96
2020-03-24 07:10:51.144 Info, Node062, ApplicationCommandHandler - Unhandled Command Class 0x32
2020-03-24 07:10:51.241 Detail, Node062, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x3e, 0x0a, 0x32, 0x02, 0x21, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xba
So it appears the network still exists, but the config in HA is toast. Not sure if there is someway to repair this or if I just need to nuke the entities and have HA rediscover them (not even sure how to do that entirely). Looking for any assistance or guidance I can try. Not really wanting to have to redo my entire network again as I have a lot of devices.
Any help would be very much appreciated.
