Updated HA 2023.9.2 -> 2023.9.3 and now Z-Wave Add-on no longer works
try to disabling Soft Reset under Z-Wave JS → Settings (cogwheel) → Z-Wave
Are you sure the USB path is correct? Searching I see /dev/serial/by-id/usb-0658_0200-if00 being used, but not /dev/serial/by-id/usb-0658_0200_if00
Got it working. For some reason after the updates, it would not get my z-wave usb stick passed through the VMware ESXi usb hub. Manually adding the USB device through my ESXi virtual machine config fixed it.
@msa This is why I always wait at least a week or two after any update release before installing. :slight_smile: The same type of issues occur for ZigBee and other components (I saw a big one for modbus recently, for example). My take is conservative: make sure every device has a fail-safe physical backup, do a complete SW backup before upgrading, and then only upgrade after each release has been out for 2-3 weeks. Annoying, but so far I’ve avoided many show-stoppers.
Lycka till!
-David
Oh yes. And we are also hampered by the time-zones, we are up early in this part of the world :slight_smile:
Tack! /Mattias
saved my day. it’s working fine now. thanks for the tips.
the VM detection must be busted because i’m using a VM with home assistant supervisor and it doesn’t seems to be detected by the plugin.
anyway, still a great plugins, and thanks for the tips :slight_smile:
Dude you just saved me at least a few days of trail and error! Thanks!
I was having the same problem after most recent z-wave update. I unplugged the z-wave ubs stick and plugged back in, which fixed my problem. Running HA on a Virtualbox on Windows 11.
Fresh install
           riable.
2023-09-30T17:22:09.742Z DRIVER   Recovering unresponsive controller failed. Restarting the driver...
Error in driver ZWaveError: Recovering unresponsive controller failed. Restarting the driver... (ZW0100)
    at Driver.destroyWithMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:2769:17)
    at fail (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:3484:14)
    at /usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:3533:5 {
  code: 100,
  context: undefined,
Shutting down
  transactionSource: undefined
Closing server...
I just managed to crash z-wave by trying to add a device config via settings. The moment I hit save the driver threw an error that it’s not able to find the device, which was fine just a second ago. Is there an issue regarding ownership of the device path or is this related to soft-reset?
Thank you, this also worked for me.
This is the way. Thank you very much :smiling_face_with_three_hearts:
Out of want of understanding - what is the flow on effect of this / why does it resolve this issue?
More so, should we re-enable this setting later / losing anything having it turned off
Like some of the others here - also running HA as an ESXI VM
Explained here:
In my case, I’m unable to re-enable the setting despite trying all the recommended options within my context. Both my dongle and ESXi are already at the recommended versions, and I’ve attempted to use the serial ID method, but I still encounter the same error.
It’s clear that this is merely a temporary workaround to make it function. I’m uncertain whether future versions will bring improvements to the soft reset for VM users.
Hello all
I had the same problem
I ma running HAOS as a vm on proxmox and i passthrough the zwave usb stick to HA
I did a back up of HA an zwave
i uninstalled and reinstalled zwave JS
i then restored from the zwave backup … it did not work
i re pairred my 10 z-wave devices now all works fine
Than you all for your help
Wow, so for my first month with HA.
MyQ = Broken
Z-Wave = Broken
The HA release model means it is in a perpetual beta state.
Various thing break monthly, but are usually fixed pretty quick before the next monthly release and a new set of issues.
I’m not a zwave user, but looking from the sidelines, it does seem to have dragged on.
MyQ has been an issue the past two or three weeks, mostly from changes on the MyQ side.
I was hoping the big 10th anniversary announcement would be something like “HA LTS”, not a generic SBC.
Not sure what’s different but the myq plugins didn’t break on HS.
Mine was fine for quite a while after the initial reports until a reboot. Then I had to apply the patch and was ok, then it stopped again for while, then started working again.
MyQ is definitely making some changes. Theory is it may not be consistent across all servers.
Silver lining is the pymyq library was picked up by @Lash-L and getting some overdue attention.
At this point I have my all local solution finally implemented, so it doesn’t matter too much.
