Hello everyone,
I updated Hass.io/Home Assistant through the Web UI and now all my Zwave light switches are listed as Unavailable:
The only Zwave device that works is my Schlage Zwave Deadbolt:
Here’s an error I see in the OZW Logs:
2020-02-08 13:21:46.640 Info, Node040, UPDATE_STATE_NODE_INFO_RECEIVED from node 40
2020-02-08 13:21:46.640 Detail, Node040, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2020-02-08 13:21:46.640 Detail, Node040, QueryStage_Dynamic
2020-02-08 13:21:46.640 Detail, Node040, Queuing (Send) SwitchBinaryCmd_Get (Node=40): 0x01, 0x09, 0x00, 0x13, 0x28, 0x02, 0x25, 0x02, 0x25, 0x86, 0x4b
2020-02-08 13:21:46.640 Detail, Node040, Queuing (Query) Query Stage Complete (Dynamic)
2020-02-08 13:21:46.641 Info, Node040, Sending (Send) message (Callback ID=0x86, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=40): 0x01, 0x09, 0x00, 0x13, 0x28, 0x02, 0x25, 0x02, 0x25, 0x86, 0x4b
2020-02-08 13:21:46.649 Detail, Node040, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-02-08 13:21:46.650 Detail, Node040, ZW_SEND_DATA delivered to Z-Wave stack
2020-02-08 13:21:46.671 Detail, Node040, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x28, 0x03, 0x25, 0x03, 0xff, 0x00
2020-02-08 13:21:46.671 Info, Node040, Response RTT 30 Average Response RTT 114
2020-02-08 13:21:46.671 Info, Node040, Received SwitchBinary report from node 40: level=On
2020-02-08 13:21:46.672 Detail, Node040, Refreshed Value: old value=false, new value=true, type=bool
2020-02-08 13:21:46.672 Detail, Node040, Changes to this value are not verified
2020-02-08 13:21:46.672 Detail, Node040, Notification: ValueChanged
2020-02-08 13:21:46.857 Detail, Node040, Received: 0x01, 0x07, 0x00, 0x13, 0x86, 0x00, 0x00, 0x15, 0x78
2020-02-08 13:21:46.857 Detail, Node040, ZW_SEND_DATA Request with callback ID 0x86 received (expected 0x86)
2020-02-08 13:21:46.857 Info, Node040, Request RTT 216 Average Request RTT 169
2020-02-08 13:21:46.857 Detail, Expected callbackId was received
2020-02-08 13:21:56.642 Error, Node040, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-02-08 13:21:56.642 Detail, Node040, Removing current message
2020-02-08 13:21:56.642 Detail, Node040, Notification: Notification - TimeOut
2020-02-08 13:21:56.647 Detail, Node040, Query Stage Complete (Dynamic)
2020-02-08 13:21:56.648 Detail, Node040, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2020-02-08 13:21:56.648 Detail, Node040, QueryStage_Configuration
2020-02-08 13:21:56.648 Detail, Node040, QueryStage_Complete
2020-02-08 13:21:56.648 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2020-02-08 13:21:56.648 Detail, Node040, Notification: NodeQueriesComplete
Here is my home-assistant.log:
config $ cat home-assistant.log
2020-02-08 13:18:07 WARNING (MainThread) [homeassistant.components.group] The 'view' option (with value 'True') is deprecated, please remove it from your configuration. This option
will become invalid in version 0.107.0
2020-02-08 13:18:44 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 17 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:44 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 17 Switch (node_id: 17) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:44 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 18 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:44 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 18 Switch (node_id: 18) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:44 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 19 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 19 Switch (node_id: 19) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 20 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 20 Switch (node_id: 20) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 21 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 3 not ready after 31 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 3 Switch (node_id: 3) not ready after 31 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 4 not ready after 31 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 21 Switch (node_id: 21) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 4 Switch (node_id: 4) not ready after 31 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 10 not ready after 31 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 22 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 10 Switch (node_id: 10) not ready after 31 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 11 not ready after 31 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 11 Switch (node_id: 11) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 12 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 12 Switch (node_id: 12) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 13 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:45 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 13 Level (node_id: 13) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 22 Switch (node_id: 22) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 23 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 23 Level (node_id: 23) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 28 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 28 Switch (node_id: 28) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 30 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 30 Switch (node_id: 30) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 31 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 31 Switch (node_id: 31) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 32 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 33 not ready after 30 seconds, continuing anyway
2020-02-08 13:18:46 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 33 Switch (node_id: 33) not ready after 30 seconds, continuing anyway
2020-02-08 13:18:47 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 43 not ready after 30 seconds, continuing anyway
and my hass.io info:
config $ hassio info
arch: aarch64
channel: stable
hassos: "3.9"
homeassistant: 0.105.2
hostname: hassio
logging: info
machine: raspberrypi3-64
supervisor: "199"
supported_arch:
- aarch64
- armv7
- armhf
timezone: America/New_York
My Zwave gateway is an: AEON Labs ZW090 Z-Stick Gen5 US
Anyone know what’s going on and how I can correct this issue to get my Zwave devices back online?
I’ve tried several reboots but it did not make any difference.
