I have done the following tests:
-Reverting back to 102.3 restores the Lovelace GUI immediately
-Removed the lines bellow from my configuration.yaml
homeassistant:
auth_providers:
# - type: legacy_api_password
# api_password: “password”
After the upgrade the homeassistant container restarts fine. I can SSH or view the logs in Portainer. I have the last following logs bellow. Note that some devices are turned off hence some of the errors.
2019-12-16 17:07:56 ERROR (stream_worker) [libav.h264] non-existing PPS 0 referenced,
2019-12-16 17:07:56 ERROR (stream_worker) [libav.h264] decode_slice_header error,
2019-12-16 17:07:56 ERROR (stream_worker) [libav.h264] no frame!,
2019-12-16 17:07:56 WARNING (MainThread) [homeassistant.components.sensor] Platform epsonworkforce not ready yet. Retrying in 30 seconds.,
2019-12-16 17:07:57 ERROR (stream_worker) [libav.tcp] Connection to tcp://192.168.x.x:8554?timeout=5000000 failed: Host is unreachable,
Exception in thread stream_worker:,
Traceback (most recent call last):,
File “/usr/local/lib/python3.7/threading.py”, line 926, in _bootstrap_inner,
self.run(),
File “/usr/local/lib/python3.7/threading.py”, line 870, in run,
self._target(*self._args, **self._kwargs),
File “/usr/src/homeassistant/homeassistant/components/stream/worker.py”, line 49, in stream_worker,
container = av.open(stream.source, options=stream.options),
File “av/container/core.pyx”, line 275, in av.container.core.open,
File “av/container/core.pyx”, line 227, in av.container.core.Container.cinit,
File “av/container/core.pyx”, line 129, in av.container.core.ContainerProxy.init,
File “av/container/core.pyx”, line 195, in av.container.core.ContainerProxy.err_check,
File “av/utils.pyx”, line 105, in av.utils.err_check,
av.AVError: [Errno 113] Host is unreachable: ‘rtsp://root:[email protected]:8554/unicast’ (16: tcp),
2019-12-16 17:07:57 ERROR (SyncWorker_14) [miio.device] Unable to discover a device at address 192.168.x.x,
2019-12-16 17:07:57 ERROR (MainThread) [custom_components.xiaomi_miio_fan.fan] Got exception while fetching the state: Unable to discover the device 192.168.x.x,
2019-12-16 17:07:57 INFO (MainThread) [homeassistant.setup] Setup of domain fan took 7.6 seconds.,
2019-12-16 17:08:06 INFO (SyncWorker_7) [homeassistant.components.nmap_tracker.device_tracker] No MAC address found for 192.168.x.x,
Then the lovelace GUI is not accessible anymore. It is quite brutal. The container reverts back automatically to 102.3 after a while and this restores the GUI.
Bellow is my config file which checks fine against a 102.3
I suspect there is something obvious causing the 103 to hang at restart. I tried to remove the custom components and the cameras at some point but it didn’t help.
homeassistant:
auth_providers:
# api_password: "password"
- type: trusted_networks
trusted_networks:
- 192.168.x.x/xx
- type: homeassistant
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: xx.x
longitude: xx.xx
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: xxx
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/London
# Customization file
customize: !include customize.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
discovery:
ignore:
- yeelight
ssdp:
zeroconf:
recorder:
purge_keep_days: 5
purge_interval: 1
cloud:
custom_updater:
track:
- components
- python_scripts
- cards
component_urls:
- https://raw.githubusercontent.com/pnbruckner/homeassistant-config/master/custom_components.json
python_script_urls:
- https://raw.githubusercontent.com/pnbruckner/homeassistant-config/master/python_scripts.json
weather:
- platform: darksky
api_key: key
scan_interval:
hours: 1
- platform: openweathermap
api_key: key
mode: freedaily
http:
base_url: https://url.com:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
huawei_lte:
- url: http://192.168.x.x/
username: login
password: password
notify:
- platform: huawei_lte
recipient: "telnumber"
# Camera
ffmpeg:
camera:
- platform: ffmpeg
input: rtmp://192.168.x.x/bcs/channel0_sub.bcs?channel=0&stream=0&user=login&password=password
- platform: ffmpeg
- platform: ffmpeg
input: rtsp://root:[email protected]:8554/unicast
- platform: ffmpeg
- platform: ffmpeg
- platform: mjpeg
still_image_url: http://192.168.x.x/webcam/?action=snapshot
mjpeg_url: http://192.168.x.x/webcam/?action=stream
# 3D Printer
octoprint:
host: 192.168.x.x
api_key: key
bed: true
number_of_tools: 1
fan:
- platform: xiaomi_miio_fan
host: 192.168.x.x
token: key
model: zhimi.fan.za3
yeelight:
devices:
192.168.x.x:
model: mono
# Sensors
monitored_conditions:
- device_information.SoftwareVersion
- device_information.WanIPAddress
- device_signal.rsrq
- device_signal.rsrp
- device_signal.sinr
- platform: moon
sensors:
moonphases:
entity_id: sensor.moon
friendly_name: 'Moon'
value_template: '{{ states.sensor.moon.state }}'
entity_picture_template: >
{% if is_state('sensor.moon', 'new_moon') %}
/local/MoonPhases/NNewMoon.jpg
{% elif is_state('sensor.moon', 'waxing_crescent') %}
/local/MoonPhases/NWaxingCrescent.jpg
{% elif is_state('sensor.moon', 'first_quarter') %}
/local/MoonPhases/NFirstQuarter.jpg
{% elif is_state('sensor.moon', 'waxing_gibbous') %}
/local/MoonPhases/NWaxingGibbous.jpg
{% elif is_state('sensor.moon', 'full_moon') %}
/local/MoonPhases/NFullMoon.jpg
{% elif is_state('sensor.moon', 'waning_gibbous') %}
/local/MoonPhases/NWaningGibbous.jpg
{% elif is_state('sensor.moon', 'last_quarter') %}
/local/MoonPhases/NLastQuarter.jpg
{% elif is_state('sensor.moon', 'waning_crescent') %}
/local/MoonPhases/NWaningCrescent.jpg
{% endif %}
sensors:
sunset_time:
value_template: '{% set timestamp = as_timestamp(states.sun.sun.attributes.next_setting) | timestamp_custom("%H:%M") %} {{ timestamp.lstrip("0") }}'
friendly_name: "Sunset"
sensors:
sunrise_time:
value_template: '{% set timestamp = as_timestamp(states.sun.sun.attributes.next_rising) | timestamp_custom("%H:%M") %} {{ timestamp.lstrip("0") }}'
friendly_name: "Sunrise"
sensors:
sun_azimuth:
value_template: "{{ state_attr('sun.sun', 'azimuth') }}"
unit_of_measurement: '°'
friendly_name: "Azimut"
sensors:
sun_elevation:
value_template: "{{ state_attr('sun.sun', 'elevation') }}"
friendly_name: "Elevation"
- platform: epsonworkforce
host: 192.168.x.x
- black
- yellow
- magenta
- cyan
host: 192.168.x.x
- black
- photoblack
- yellow
- magenta
- cyan
- platform: enphase_envoy
ip_address: 192.168.x.x
- production
- daily_production
- seven_days_production
- lifetime_production
- platform: syncthru
resource: http://192.168.x.x
- platform: nut
host: 192.168.x.x
port: 3493
alias: upsname
username: login
password: password
resources:
- ups.status.display
- ups.load
- input.voltage
- battery.runtime
# Binary Sensors
binary_sensor:
- platform: mqtt
state_topic: 'home/motion'
device_class: motion
off_delay: 3
- platform: mqtt
state_topic: 'home/ceiling'
off_delay: 3
- platform: mqtt
state_topic: 'home/door1'
device_class: door
- platform: mqtt
state_topic: 'home/door2'
device_class: door
# Media Players
media_player:
- platform: squeezebox
host: 192.168.x.x
host: 192.168.x.x
host: 192.168.x.x
host: 192.168.x.x
# Device Tracker
device_tracker:
- platform: nmap_tracker
hosts: 192.168.x.x/xx
track_new_devices: yes
interval_seconds: 20
consider_home: 60
life360:
accounts:
- username: !secret life360_username
password: !secret life360_password
driving_speed: 30
interval_seconds: 10
max_gps_accuracy: 100
# Text to speech
tts:
- platform: google_translate
cache: true
cache_dir: /tmp/tts
time_memory: 300
base_url: https://url.ui.nabu.casa
service_name: google_say
language: 'en'
python_script:
group: !include groups.yaml
script: !include scripts.yaml
