Hey @spry-salt . I can confirm that (with a recently installed Australian SolarEdge SE8250H inverter) I have managed to get Modbus over TCP working on Wifi - it was running the latest firmware 4.16.19 which SolarEdge installed during some troubleshooting and it worked perfectly. However, that inverter had other issues and had to be swapped out under warranty. Now I have a replacement running on the older firmware 4.15.119 and it has stopped sending the Modbus data. I have a ticket in with SolarEdge to get the new August 2022 firmware installed and hopefully that will fix it once more. Iāll report back.
ah dang sorry I just saw this. Do you have an installer account on solaredge or something? I donāt have that level of detail anywhere in the interface from what I can tell.
Iāve gone back and forth with solaredge support a couple times at this point, but they are very slow to respond. I sent them a wireshark pcap a couple weeks ago where I was just manually reading registers using this command-line tool. They sent me this link: https://solared.ge/modbus-tcp which includes a broken link to the āPower Control Protocol Application Noteā that everyone has been using to implement the battery registers in their various libraries. The one everyone has been using is from 2017, so itās possible thereās a new version that has the correct registers in it.
Honestly I might write a script that just loops through addresses and sees if there are some registers somewhere that arenāt documented.
If you have any luck with solaredge support or any of this, please let me know⦠Iāll try to keep a closer eye on this, I figured Iād get an email if someone replied but I guess not.
try this repo in hacs:
I tried your fix, but I still get the 0 a lot.
I will look into it
Thanks. How did you convince them to update your firmware? Iāve asked my installer but I donāt know whether theyāll be willing to do it.
Let us know how you get on, Iāve not seen any zeros on house consumption since and am keen to make this family proof without them questioning the accuracy!
I havenāt yet
I have a ticket open with SolarEdge directly asking for it to be done. They havenāt said they wonāt do it so Iām hopeful. Theyāre inundated with tickets though and it has to be escalated to a senior engineer. Iāll chase them tomorrow if I donāt hear anything today.
That looks interesting. Iād love to get panel-level data into HA. I tried it but had an āInvalid authenticationā error. I wonder whether thatās because I have a regular genesis SE8250H and not the Energy Hub version (or the Genesis Enhancement Pack) which adds the panel level monitoring)?
No replies - is there a trick (or hardware) I need to get the M1 data showing up? Without that info, none of the great graphs in this post are working. Thanks.
Seems I did the same thing and am in the same boat. M1 data doesnāt appear. Not clear what the solution is. Ethernet should be all we need. Some portion of this is obviously working because we get a bunch of other values over it just not the M1.
I do not know the physical layout but did you try m2 or m3. No idea if thats something the installer could have done, just thinking out loud.
Hi everybody,
I do have a question. Itās not directly for the Homeassistent communication but here are the experts
I checked my consumption from grid accord to solaredge and from my local energy meter. Solaredge says 25 kWh and my energy meter (evu) 45 kWh over 2
1/2 month .
Is this difference normal or do I have to check the measurement?
Thank you for your help.
Does anyone know a way to get remote control of the battery for a setapp Solaredge inverter? Reading through forums and manuals for hours and the only options I can see are MSC (Self Consumption) and ToU (time of use).
I would love to be able to control the battery through HA to charge from the grid overnight on cheap rates but only somedays where PV production wont fill the battery.
Running a SE4000H inverter, SE Energy Bank 10kW, SE optimizers and Trina panels if that makes any difference.
Yeah, Iāve tried 1,2,3 with nothing showing for the latter.
I have setapp access so I can mess with things if I need to.
All I see are two RS485 connections set to SolarEdge forwarder and then the enabling of ModBus over TCP/IP which is enabled.
I guess the issue is related to where M1 comes from.
I didnāt think something else was required other than āModBus over TCPā ?
Does anybody knows if the Solaredge inverter (SE6000h or another one) could work witout optimizers?
I m thinking to install PV, but my installer propose me a Solaredge Inverter wihtout Optimizers (no SMA, Fronius, Huawei inverter available).
Hey @Remko,
had some time to redo my calculations. The »strange look« is just due to some extra configurations like
hide_inactive_lines: 1
show_gap: true
explained in the repository of the Tesla style solar power card : GitHub - reptilex/tesla-style-solar-power-card: Home assistant power card mimicking the one tesla provides for the powerwall app.
I also changed the icons and so on.
UPDATE:
So here is my new energy.yaml for the 2 inverter situation. I work with local variables to have a better understanding of the calculations, wich appear much cleaner this was:
template:
- sensor:
- name: "Solar Selfconsumption Ratio"
unique_id: solar_selfconsumption_ratio
icon: mdi:percent-outline
state: >
{% set panel_to_house_daily = states('sensor.solar_panel_to_house_daily') | float(0) %}
{% set battery_in_daily = states('sensor.solar_battery_in_daily') | float(0) %}
{% set exported_power_daiy = states('sensor.solar_exported_power_daiy') | float(0) %}
{% if (panel_to_house_daily + battery_in_daily + exported_power_daiy <= 0) %}
0
{% else %}
{{ ((panel_to_house_daily + battery_in_daily) / (panel_to_house_daily + battery_in_daily + exported_power_daiy) * 100) | round (1) }}
{% endif %}
- name: "Solar Autarkie Ratio"
unique_id: solar_autarkie_ratio
state: >
{% set house_consumption_daily = states('sensor.solar_house_consumption_daily') | float(0) %}
{% set imported_power_daily = states('sensor.solar_imported_power_daily') | float(0) %}
{% if (house_consumption_daily <= 0) %}
0
{% else %}
{{ (1 - (imported_power_daily / house_consumption_daily) * 100) | round (1) }}
{% endif %}
- name: "Solar Inverter Effectiveness"
unique_id: solar_inverter_effectiveness
unit_of_measurement: "%"
state: >
{% set i1_dc_power = states('sensor.solaredge_i1_dc_power') | float(0) %}
{% set i2_dc_power = states('sensor.solaredge_i2_dc_power') | float(0) %}
{% set i1_ac_power = states('sensor.solaredge_i1_ac_power') | float(0) %}
{% set i2_ac_power = states('sensor.solaredge_i2_ac_power') | float(0) %}
{% set inverter_effectiveness = states('sensor.solar_inverter_effectiveness') %}
{% if (is_state('sensor.solar_inverter_effectiveness', 'unknown')) %}
1
{% elif (i1_dc_power + i2_dc_power < 100 or i1_ac_power + i2_ac_power < 100) %}
{{ inverter_effectiveness }}
{% else %}
{{ (i1_ac_power + i2_ac_power) / (i1_dc_power + i2_dc_power) }}
{% endif %}
- name: "Solar Battery Effectiveness"
unique_id: solar_battery_effectiveness
state: >
{% set b1_dc_power = states('sensor.solaredge_b1_dc_power') | float(0) %}
{% set battery_effectiveness = states('sensor.solar_battery_effectiveness') %}
{% if (is_state('sensor.solar_battery_effectiveness', 'unknown') or (solar_battery_effectiveness == 0)) %}
1
{% elif (i1_dc_power + i2_dc_power + b1_dc_power <= 0) %}
{% if (b1_dc_power >= 0 or i1_dc_power + i2_dc_power <= 0) %}
{{ battery_effectiveness }}
{% else %}
{{ (1 - ((b1_dc_power * -1 - (i1_dc_power + i2_dc_power)) / b1_dc_power * -1)) }}
{% endif %}
{% else %}
{% endif %}
- name: "Solar Panel Production W"
unique_id: solar_panel_production_w
unit_of_measurement: "W"
icon: mdi:solar-power
state: >
{% if (is_state('sensor.solaredge_i1_dc_power', 'unknown') or is_state('sensor.solaredge_i2_dc_power', 'unknown') or is_state('sensor.solaredge_b1_dc_power', 'unknown')) %}
0
0
{% else %}
{{ (i1_dc_power + i2_dc_power + b1_dc_power) }}
{% endif %}
- name: "Solar Panel To House W"
unique_id: solar_panel_to_house_w
state: >
{% set m1_ac_power = states('sensor.solaredge_m1_ac_power') | float(0) %}
{% set inverter_effectiveness = states('sensor.solar_inverter_effectiveness') | float(0) %}
{% if (b1_dc_power >= 0 and m1_ac_power > 0) %}
{% if (i1_dc_power < 0 and i1_ac_power <= 0) %}
{{ (i1_dc_power + i2_ac_power - m1_ac_power) }}
{% else %}
{{ (i1_ac_power + i2_ac_power - m1_ac_power) }}
{% endif %}
{% elif (b1_dc_power >= 0 and m1_ac_power <= 0) %}
{{ (i1_dc_power + i2_ac_power) }}
{% else %}
{{ (i1_ac_power + i2_ac_power) }}
{% endif %}
{% elif (b1_dc_power < 0) %}
{% if (i1_dc_power + i2_dc_power + b1_dc_power < 0) %}
0
{% else %}
{{ ((i1_dc_power + i2_dc_power + b1_dc_power) * inverter_effectiveness) }}
{% endif %}
{% else %}
0
{% endif %}
- name: "Solar Panel To Battery W"
unique_id: solar_panel_to_battery_w
state: >
{% set grid_to_battery_w = states('sensor.solar_grid_to_battery_w') | float(0) %}
{% if (b1_dc_power > 0) %}
{% if (grid_to_battery_w > 0) %}
0
{% else %}
{{ b1_dc_power }}
{% endif %}
{% else %}
0
{% endif %}
- name: "Solar Panel To Grid W"
unique_id: solar_panel_to_grid_w
state: >
{% set panel_production_w = states('sensor.solar_panel_production_w') | float(0) %}
{% set exported_power_w = states('sensor.solar_exported_power_w') | float(0) %}
{% if (exported_power_w > 0 and panel_production_w > 0) %}
{% if (exported_power_w > panel_production_w) %}
{{ panel_production_w }}
{% else %}
{{ exported_power_w }}
{% endif %}
{% else %}
0
{% endif %}
- name: "Solar Battery To House W"
unique_id: solar_battery_to_house_w
icon: mdi:battery-negative
state: >
{% set battery_effectiveness = states('sensor.solar_battery_effectiveness') | float(0) %}
{% if (b1_dc_power < 0) %}
{{ (b1_dc_power * -1 * battery_effectiveness * inverter_effectiveness) }}
{% else %}
0
{% endif %}
- name: "Solar Battery To Grid W"
unique_id: solar_battery_to_grid_w
state: >
{% set panel_to_grid_w = states('sensor.solar_panel_to_grid_w') | float(0) %}
{% if (exported_power_w > panel_to_grid_w) %}
{{ exported_power_w - panel_to_grid_w }}
{% else %}
0
{% endif %}
- name: "Solar Grid To House W"
unique_id: solar_grid_to_house_w
icon: mdi:transmission-tower-export
state: >
{% if (m1_ac_power <= 0) %}
{{ (m1_ac_power * -1) }}
{% else %}
0
{% endif %}
- name: "Solar Grid To Battery W"
unique_id: solar_grid_to_battery_w
icon: mdi:battery-positive
state: >
{% if (i1_ac_power <= 0 and i2_ac_power <= 0 and b1_dc_power > 0) %}
{{ b1_dc_power }}
{% else %}
0
{% endif %}
- name: "Solar Battery In W"
unique_id: solar_battery_in_w
state: >
{% set panel_to_battery_w = states('sensor.solar_panel_to_battery_w') | float(0) %}
{{ (grid_to_battery_w + panel_to_battery_w) }}
- name: "Solar House Consumption W"
unique_id: solar_house_consumption_w
icon: mdi:home
state: >
{% set panel_to_house_w = states('sensor.solar_panel_to_house_w') | float(0) %}
{% set battery_to_house_w = states('sensor.solar_battery_to_house_w') | float(0) %}
{% set grid_to_house_w = states('sensor.solar_grid_to_house_w') | float(0) %}
{{ (panel_to_house_w + battery_to_house_w + grid_to_house_w) }}
- name: "Solar Imported Power W"
unique_id: solar_imported_power_w
state: >
{% if (m1_ac_power < 0) %}
{% else %}
0
{% endif %}
- name: "Solar Exported Power W"
unique_id: solar_exported_power_w
icon: mdi:transmission-tower-import
state: >
{% if (m1_ac_power > 0) %}
{{ (m1_ac_power) }}
{% else %}
0
{% endif %}
- name: "Solar Lifetime Production"
unique_id: solar_lifetime_production
unit_of_measurement: "MWh"
state: >
{% set ac_energy_kwh = states('sensor.solaredge_ac_energy_kwh') | float(0) %}
{{ ((ac_energy_kwh / 1000) | round (2)) }}
- platform: integration
source: sensor.solar_panel_production_w
method: left
unit_prefix: k
source: sensor.solar_battery_to_house_w
method: left
unit_prefix: k
source: sensor.solar_battery_in_w
method: left
unit_prefix: k
source: sensor.solar_house_consumption_w
method: left
unit_prefix: k
source: sensor.solar_imported_power_w
method: left
unit_prefix: k
source: sensor.solar_exported_power_w
method: left
unit_prefix: k
source: sensor.solar_panel_to_house_w
method: left
unit_prefix: k
- platform: statistics
name: "Solar Battery Effectiveness Average"
unique_id: solar_battery_effectiveness_average
state_characteristic: mean
sampling_size: 1200
max_age:
hours: 24
entity_id: sensor.solar_battery_effectiveness
name: "Solar Inverter Effectiveness Average"
unique_id: solar_inverter_effectiveness_average
sampling_size: 1200
max_age:
hours: 24
entity_id: sensor.solar_inverter_effectiveness
utility_meter:
solar_panel_production_daily:
source: sensor.solar_panel_production_kwh
name: Solar Panel Production Daily
cycle: daily
solar_battery_in_daily:
source: sensor.solar_battery_in_kwh
name: Solar Battery In Daily
cycle: daily
solar_battery_out_daily:
source: sensor.solar_battery_out_kwh
name: Solar Battery Out Daily
cycle: daily
solar_house_consumption_daily:
source: sensor.solar_house_consumption_kwh
name: Solar House Consumption Daily
cycle: daily
solar_imported_power_daily:
source: sensor.solar_imported_power_kwh
name: Solar Imported Power Daily
cycle: daily
solar_imported_power_daily_solaredge:
source: sensor.solaredge_m1_imported_kwh
name: Solar Imported Power Daily Solar Edge
cycle: daily
solar_exported_power_daily:
source: sensor.solar_exported_power_kwh
name: Solar Exported Power Daily
cycle: daily
solar_panel_to_house_daily:
source: sensor.solar_panel_to_house_kwh
name: Solar Panel To House Daily
cycle: daily
solar_panel_to_house_weekly:
name: Solar Panel To House Weekly
cycle: weekly
solar_imported_power_weekly:
name: Solar Imported Power Weekly
cycle: weekly
solar_house_consumption_weekly:
name: Solar House Consumption Weekly
cycle: weekly
solar_panel_production_weekly:
name: Solar Panel Production Weekly
cycle: weekly
solar_battery_in_weekly:
name: Solar Battery In Weekly
cycle: weekly
solar_battery_out_weekly:
name: Solar Battery Out Weekly
cycle: weekly
solar_exported_power_weekly:
name: Solar Exported Power Weekly
cycle: weekly
solar_panel_to_house_monthly:
name: Solar Panel To House Monthly
cycle: monthly
solar_imported_power_monthly:
name: Solar Imported Power Monthly
cycle: monthly
solar_house_consumption_monthly:
name: Solar House Consumption Monthly
cycle: monthly
solar_panel_production_monthly:
name: Solar Panel Production Monthly
cycle: monthly
solar_battery_in_monthly:
name: Solar Battery In Monthly
cycle: monthly
solar_battery_out_monthly:
name: Solar Battery Out Monthly
cycle: monthly
solar_exported_power_monthly:
name: Solar Exported Power Monthly
cycle: monthly
solar_panel_to_house_yearly:
name: Solar Panel To House Yearly
cycle: yearly
solar_imported_power_yearly:
name: Solar Imported Power Yearly
cycle: yearly
solar_house_consumption_yearly:
name: Solar House Consumption Yearly
cycle: yearly
solar_panel_production_yearly:
name: Solar Panel Production Yearly
cycle: yearly
solar_battery_in_yearly:
name: Solar Battery In Yearly
cycle: yearly
solar_battery_out_yearly:
name: Solar Battery Out Yearly
cycle: yearly
solar_exported_power_yearly:
name: Solar Exported Power Yearly
cycle: yearly
I tweaked the »solar_panel_to_grid_w« sensor and added a »solar_battery_to_grid_w« sensor as well. So now all occurring energy flows are covered:
And for the sake of completeness here is what my tesla-style-solar-power-card configuration looks like:
- type: custom:tesla-style-solar-power-card
name: Home Energy Flow
# 7 flows between bubbles
grid_to_house_entity: sensor.solar_grid_to_house_w
grid_to_battery_entity: sensor.solar_grid_to_battery_w
generation_to_grid_entity: sensor.solar_panel_to_grid_w
generation_to_battery_entity: sensor.solar_panel_to_battery_w
generation_to_house_entity: sensor.solar_panel_to_house_w
battery_to_house_entity: sensor.solar_battery_to_house_w
battery_to_grid_entity: sensor.solar_battery_to_grid_w
# extra values to show as text above icons
battery_extra_entity: sensor.solaredge_b1_state_of_energy
house_extra_entity: sensor.aussentemperatur
generation_extra_entity: sensor.cloud_coverage_guetersloh
# grid_extra_entity: sensor.solar_exported_power_daily
# optional appliances with consumption and extra values
# appliance1_consumption_entity: sensor.car_consumption
# appliance1_extra_entity: sensor.car_battery_state_of_charge
# appliance2_consumption_entity: sensor.heating_consumption
# appliance2_extra_entity: sensor.heating_operation
# optional 4 main bubble icons for clickable entities
# grid_entity: sensor.grid_consumption
# house_entity: sensor.house_consumption
# generation_entity: sensor.solar_yield
# battery_entity: sensor.battery_consumption
show_gap: true
threshold_in_k: 1
grid_icon: mdi:transmission-tower
generation_icon: mdi:solar-power-variant-outline
house_icon: mdi:home-lightning-bolt-outline
battery_icon: mdi:battery-high
I hope some of you can use this!
SolarEdge kindly remotely updated the firmware on my inverter and modbus is now working over wifi.
Iām the author of solaredge-modbus-multi so if youāre having problems with it that are something I can improve on, please let me know.
Thanks. We already had some contact where your fixed an issue with the additional meter showing up. I now have it all running for a while without any issues. Just still need to post there new configs for that. Still got some minor modifications to implement, but no issues so far!
Oh yes, the changing meter ID thing. I remember now, didnāt make the connection right away.
