I messed up my installation by changing the HA wlan to a static IP address fas I can’t access the Hass io via browser / app. The previous setting was based on DHCP
The HA cli starts all nice and I can see that the newly added IP to wlan is the same I changed it to.
I’ve now learned that I should have at least assigned the same static IP address to HA in the router settings before doing this, and most likely there’s many other steps as well. I’m failing to assign this IP address in the router settings as even though HA is connected to the router, I just can’t seem to find the mac address of HA.
how do you run HA? You could connect a device (laptop for example) to the same switch and set that device to an IP in the same network. For example if you set 10.0.0.20 on HA set 10.0.0.21 on the laptop and you should be able to connect. You could also connect directly without a switch most likely.
Thank you for your answer fleskefjes! To be short, I got the Hass io working after some tinkering (not sure exactly what fixed it at this point), but now I can access Hass io via browser (with nabu casa) and I’m able to find my raspberry PI Home assistant that’s connected to the router, after I reverted back to DHCP for END0 connections.
