I updated to hass.io 0.6 this morning using the update button, I left it for about half an hour then came back and refreshed my page but got a connection refused error.
I had confgurator open too so tried refreshing that too and it loaded fine.
I tried power cycling and still no joy.
I’m running on a PI 3 over cat5, with it booting from USB using a WD pidrive (no SD I’ve set the USB boot bit on my PI).
I can get in to my logs with samba, this is all it says:
2017-12-24 13:24:55 ERROR (SyncWorker_0) [homeassistant.util.yaml] mapping values are not allowed here
in “/config/configuration.yaml”, line 53, column 13
2017-12-24 13:24:55 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: mapping values are not allowed here
Looking at that code snippet again some of the other spacings look a bit off too, but it might be how it’s rendering on my phone (and my eyes!), so worst case scenario just comment out that whole bit and then double check the spaces.
