Updates for HACS ore working,
but not for add-ons or HA core,
When I check for updates there simply aren’t any.
Core 2024.9.1
Supervisor 2024.09.1
Operating System 13.1
Frontend 20240906.0
no new esphome or core 2024 are found,
nothing is in the log.
My DNS server shows checkonline.home-assistant.io is requested.,
however when I try to reach this as a website, I got this message after waiting for a long long time
then the status page is showing all is working well
I have this issue for a couple of days, and do not find anyone during this time having the same issue, So I assume it’s something at my side.
Back then, my pi-hole server was acting up, So I needed another location to store it. then I totally forgot about it.
But I need to plan this, because running both pihole and adguard on the same machine even for a little while might causes issues.
I was saying to get rid of pihole in favor of adguard. I tried both back when pihole was an addon and I ended up sticking with adguard home instead. Take it with a grain of salt though, this isn’t my strongest area.
maybe point your router/gateway to normal dns servers first (you’ll get ads though), then remove pihole and then add adguard? I don’t remember how pihole worked
thnx @petro
I installed adguard home on my router (modified my DHCP server)
removed the pi-hole container
uninstalled portainer
restarted the supervisor,
and I see some add on updates again.
