Updating 3-way switch automation
I have 3-way switch operation running successfully including the target of automation using the following MQTT construct in configuration.yaml
  - platform: mqtt
    state_topic: "stat/tasmota_XXXXX/POWER1"
    command_topic: "cmnd/tasmota_XXXXX/EVENT"
    availability_topic: "tele/tasmota_XXXXX/LWT"
    qos: 0
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
After a recent upgrade, I get the following warning
However, clicking on the “Documentation” link did not help me figure out what I should be doing.
Any help will be greatly appreciated.
I assume your current configuration is under the switch key, this needs moving to be under the mqtt:
from
switch:
  - platform: mqtt
      ...etc
to
mqtt:
  switch:
    - name: "Exterior Lights"
        ...etc
Thank you very much!
For some reason, the entities are no longer showing up. I wonder if I messed up by adding multiple switches using the following syntax:
mqtt:
  switch:
        ...etc
    - name: "Interior Lights"
      state_topic: "stat/tasmota_YYYYY/POWER1"
        ...etc
The configuration looks correct and matches my working one. Did you get this working or is it still an issue?
I tried using a switch: subkey before every “- name” and that did it for me.
