So I recently did a major update to HA and stepped through multiple versions. I got so far behind because HA was so damn stable that everything just worked.
Anyways I had an old binary sensor that was created with a value template. It is no longer working as the sensors the value template now have a value when they are off, previously they had no value assigned.
Basically I need to check sensor.advisories, sensor.statements, sensor.watches, and sensor.warnings and if any of them have a value that isn’t ‘0’ the 'bad_weather binary sensor is set to ‘on’ if all of the sensor’s have a value of ‘0’ then bad_weather is set to ‘off’.
@123@finity Thanks for the help.
Turns out I at some point had gone a completely different direction with my weather alert card and I forgot to remove the bad_weather binary sensor.
