Updating Aqara device firmware in Home Assistant via ZHA
I have a Zigbee dongle that works well with Home Assistant via ZHA and it’s not limited to Aqara, which allows me to limit the number of gateways and hardware. Is there a way to update my Aqara sensors and devices’ firmware via ZHA in Home Assistant? If not, if I was to get the gateway, would I be able to map my devices back to Home Assistant and have them present on both the Aqara hub and ZHA?
Hi, I have exactly the same question. Have you found an answer?
Did either of you find a way of doing it?
Same question. @Max6993109 , did you get the gateway and tried updating the firmware?
