Updating Core to 0.117 failing on RPi 4 in venv
Trying to do the latest upgrade for 2 days for HA Core running in a venv on RPi 4, from 0.116.4 as per usual but get the following errors when trying to install dependencies; tried ignoring the pip cache and no joy. Any one else getting this or have any brain waves?
ERROR: Command errored out with exit status 1:
   command: /srv/homeassistant/bin/python3.8 /srv/homeassistant/lib/python3.8/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-zuuacv2u/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.8,!=1.11.3; platform_python_implementation != '"'"'PyPy'"'"''
       cwd: None
  Complete output (31 lines):
    File "/usr/local/lib/python3.8/runpy.py", line 192, in _run_module_as_main
      return _run_code(code, main_globals, None,
    File "/usr/local/lib/python3.8/runpy.py", line 85, in _run_code
      exec(code, run_globals)
    File "/srv/homeassistant/lib/python3.8/site-packages/pip/__main__.py", line 26, in <module>
      sys.exit(_main())
    File "/srv/homeassistant/lib/python3.8/site-packages/pip/_internal/cli/main.py", line 73, in main
      command = create_command(cmd_name, isolated=("--isolated" in cmd_args))
    File "/srv/homeassistant/lib/python3.8/site-packages/pip/_internal/commands/__init__.py", line 104, in create_command
      module = importlib.import_module(module_path)
    File "/usr/local/lib/python3.8/importlib/__init__.py", line 127, in import_module
      return _bootstrap._gcd_import(name[level:], package, level)
    File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
    File "<frozen importlib._bootstrap>", line 991, in _find_and_load
    File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
    File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
    File "<frozen importlib._bootstrap_external>", line 783, in exec_module
    File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
    File "/srv/homeassistant/lib/python3.8/site-packages/pip/_internal/commands/install.py", line 17, in <module>
      from pip._internal.cli.req_command import RequirementCommand, with_cleanup
    File "/srv/homeassistant/lib/python3.8/site-packages/pip/_internal/cli/req_command.py", line 22, in <module>
      from pip._internal.req.constructors import (
    File "/srv/homeassistant/lib/python3.8/site-packages/pip/_internal/req/__init__.py", line 10, in <module>
      from .req_install import InstallRequirement
    File "/srv/homeassistant/lib/python3.8/site-packages/pip/_internal/req/req_install.py", line 10, in <module>
      import uuid
    File "/srv/homeassistant/lib/python3.8/site-packages/uuid.py", line 138
      if not 0 <= time_low < 1<<32L:
  SyntaxError: invalid syntax
Uninstall the uuid package
This worked - thanks very much Nick. Any idea why, or just there was clearly a fault with the UUID package and removing it was the fastest route to fixing?!
Thanks again.
uuid and typing are blocked from being installed via homeassistant because they break newer python versions.
