Updating dashboard with new Hue scenes
Hi
I have a newbe question.
I have just installed Home Assistant on a windows pc using VirtualBox.
I have integrated my Philips Hue.
My problem is that I changed som scenes in my Hue App but they are not showing up on Home Assistant dashboard.
How do I update the dashboard with the new Hue scenes?
Hi and welcome to the forums.
Have you already tried to reload the Hue integration (settings —> integrations) ?
Hi thanks for responding. Yes I tried that. Also restartet Hue Hub and HA.
I have now manually changed the code and added the scenes.
Just thougth HA could do it again like when I integrated them the first time.
You might have a look at the entities list of the integration. Maybe the edited scene is registered as new one and deactivated.
Hi again. Just tried to add a new scene in HUE App and I found the scene in the entity list but it is enabled. I can also activate it from there - works fine. But it’s not displayed on the dashboard only if I change the yaml file it will show.
Are we talking about the default dashboard that is auto-generated or one that you’ve created?
I guess I have made it. Not sure what you mean.
