So I pulled the latest docker image and the container is failing to start because it seems that the entrypoint script is missing:
[FATAL tini (6)] exec /bin/entry.sh failed: No such file or directory
I took a look inside the image and saw that indeed the script is missing. Was this changed in 0.107 or something, or was it just a mistake in the creation of the image? I don’t really know if I should just copy the script from the old image into the new one - or how to do it, really.
Thank you for the question - this took me some googling and trying.
Can this be posted as a breaking change on the docker installation (update) instructions?
Welcome to the community - but you will realize this project moves quickly and breaks a ton of stuff in the name of progress. The community liaison has already said it’s not a HA issue and to blame Portainer which is pretty much the status quo.
Yes, but unfortunately the docker image was changed without any mention in any of the release notes, which triggered the issue with an upgrade process in Portainer that has worked since the docker images began being published…
No point reading the release notes if they are incomplete and leave out such details.
It doesn’t but I believe it creates that based on the image it installs.
I never created an entry point to use when I originally started running HA on docker but mine had the entry point in the portainer config nonetheless. I just removed my original container and the old images and re-created it from scratch using my original docker run command and it automatically changed the image entry point config to /init/.
It is a Portainer caching issue but I still think it should have been included in the release notes since it prevents a large number of people from doing an upgrade without knowing that information.
Mine was actually upgraded by ouroboros, so it’s not really exclusive to portainer. Although I had the same issue when I tried to fix it with Portainer.
