Updating fails - How to clear up some free space on RPi SD card?
I’m running 0.105.1 and have deleted /config/home-assistant_V2.db and all snapshots and there’s still not enough free space to update (at least I think that’s the problem…). I also searched for large files and there’s nothing too big…
Are there any log directories or other that I should look in for lots of unnecessary small files?
20-03-02 19:19:36 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.106.2 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:0.106.2: No such image: homeassistant/raspberrypi3-homeassistant:0.106.2").
20-03-02 19:19:36 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
20-03-02 19:19:36 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<process_lock.<locals>.wrap_api() done, defined at /usr/src/supervisor/supervisor/utils/__init__.py:22> exception=HomeAssistantUpdateError()>
  File "/usr/src/supervisor/supervisor/utils/__init__.py", line 31, in wrap_api
    return await method(api, *args, **kwargs)
  File "/usr/src/supervisor/supervisor/homeassistant.py", line 361, in update
    raise HomeAssistantUpdateError()
supervisor.exceptions.HomeAssistantUpdateError
Hi, I have the same problem for few days. But i think is not a problem with free space because I have 83% free storage (22.4GB).
Can someone tell us the resolution to fix this? I have 0.102.3 which tried update to 0.106.2
Logs:
20-03-02 21:51:51 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.106.2
20-03-02 21:51:51 INFO (SyncWorker_15) [supervisor.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.102.3 to homeassistant/raspberrypi3-homeassistant:0.106.2
20-03-02 21:51:51 INFO (SyncWorker_15) [supervisor.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.106.2.
20-03-02 21:53:00 ERROR (SyncWorker_15) [supervisor.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.106.2 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:0.106.2: No such image: homeassistant/raspberrypi3-homeassistant:0.106.2").
20-03-02 21:53:00 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
20-03-02 21:57:42 INFO (SyncWorker_13) [supervisor.docker.interface] Restart homeassistant/raspberrypi3-homeassistant
Anyone help?
After deleting large files, did you also issue a Linux ‘sync’ command to insure it was all written to the disk?
sync; sync
I’ve had installs fail with this error a lot, but it eventually works. Other threads point to a corrupt DB or failing SD card.
