Hi, trying to upgrade my Home Assistant Core 2022.6.7 to 2022.7.3 on my TrueNAS Core Version: TrueNAS-13.0-U1
But I get an error message -
Downloading orjson-3.7.5.tar.gz (640 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 640.2/640.2 KB 33.2 MB/s eta 0:00:00
Installing build dependencies … error
error: subprocess-exited-with-error
× pip subprocess to install build dependencies did not run successfully.
│ exit code: 1
╰─> [102 lines of output]
Collecting maturin<0.13,>=0.12.19
Downloading maturin-0.12.20.tar.gz (156 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 156.9/156.9 KB 5.5 MB/s eta 0:00:00
Installing build dependencies: started
Installing build dependencies: finished with status ‘done’
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status ‘done’
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status ‘done’
Collecting tomli>=1.1.0
Downloading tomli-2.0.1-py3-none-any.whl (12 kB)
Building wheels for collected packages: maturin
Building wheel for maturin (pyproject.toml): started
Building wheel for maturin (pyproject.toml): finished with status ‘error’
× Building wheel for maturin (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [77 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.freebsd-12.2-RELEASE-p14-amd64-3.9
creating build/lib.freebsd-12.2-RELEASE-p14-amd64-3.9/maturin
copying maturin/import_hook.py -> build/lib.freebsd-12.2-RELEASE-p14-amd64-3.9/maturin
copying maturin/__init__.py -> build/lib.freebsd-12.2-RELEASE-p14-amd64-3.9/maturin
running build_ext
running build_rust
Downloading crates ...
error: failed to download `scroll v0.11.0`
Caused by:
unable to get packages from source
Caused by:
failed to parse manifest at `/home/homeassistant/.cargo/registry/src/github.com-1ecc6299db9ec823/scroll-0.11.0/Cargo.toml`
Caused by:
feature `edition2021` is required
The package requires the Cargo feature called `edition2021`, but that feature is not stabilized in this version of Cargo (1.55.0).
Consider trying a newer version of Cargo (this may require the nightly release).
See https://doc.rust-lang.org/nightly/cargo/reference/unstable.html#edition-2021 for more information about the status of this feature.
File "/tmp/tmp8s47tk37_in_process.py", line 363, in <module>
main()
File "/tmp/tmp8s47tk37_in_process.py", line 345, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/tmp/tmp8s47tk37_in_process.py", line 261, in build_wheel
return _build_backend().build_wheel(wheel_directory, config_settings,
File "/tmp/pip-build-env-ias8tab4/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 216, in build_wheel
return self._build_with_temp_dir(['bdist_wheel'], '.whl',
File "/tmp/pip-build-env-ias8tab4/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 202, in _build_with_temp_dir
self.run_setup()
File "/tmp/pip-build-env-ias8tab4/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 145, in run_setup
exec(compile(code, __file__, 'exec'), locals())
File "setup.py", line 57, in <module>
setup(
File "/tmp/pip-build-env-ias8tab4/overlay/lib/python3.9/site-packages/setuptools/__init__.py", line 153, in setup
return distutils.core.setup(**attrs)
File "/usr/local/lib/python3.9/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/local/lib/python3.9/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/usr/local/lib/python3.9/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-ias8tab4/overlay/lib/python3.9/site-packages/wheel/bdist_wheel.py", line 299, in run
self.run_command('build')
File "/usr/local/lib/python3.9/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/local/lib/python3.9/distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-build-env-ias8tab4/overlay/lib/python3.9/site-packages/setuptools_rust/setuptools_ext.py", line 132, in run
build_rust.run()
File "/tmp/pip-build-env-ias8tab4/overlay/lib/python3.9/site-packages/setuptools_rust/command.py", line 101, in run
self.run_for_extension(ext)
File "/tmp/pip-build-env-ias8tab4/overlay/lib/python3.9/site-packages/setuptools_rust/build.py", line 112, in run_for_extension
dylib_paths = self.build_extension(ext, self.target)
File "/tmp/pip-build-env-ias8tab4/overlay/lib/python3.9/site-packages/setuptools_rust/build.py", line 143, in build_extension
target_dir = _base_cargo_target_dir(ext)
File "/tmp/pip-build-env-ias8tab4/overlay/lib/python3.9/site-packages/setuptools_rust/build.py", line 690, in _base_cargo_target_dir
target_directory = ext._metadata()["target_directory"]
File "/tmp/pip-build-env-ias8tab4/overlay/lib/python3.9/site-packages/setuptools_rust/extension.py", line 225, in _metadata
self._cargo_metadata = json.loads(subprocess.check_output(metadata_command))
File "/usr/local/lib/python3.9/subprocess.py", line 424, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/local/lib/python3.9/subprocess.py", line 528, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['cargo', 'metadata', '--manifest-path', 'Cargo.toml', '--format-version', '1']' returned non-zero exit status 101.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for maturin
Failed to build maturin
ERROR: Could not build wheels for maturin, which is required to install pyproject.toml-based projects
[end of output]
[end of output]
│ exit code: 1
╰─> See above for output.
note: This error originates from a subprocess, and is likely not a problem withpip.
