Updating from v.0.114.4 to 0.115.6 caused a very slow system
after updating from 114.4 to 115.6 my home assistant runs unstably and absolutely slowly. It seems to be completely thwarted. When I downgrade to 114.4 everything works fine again. If I switch a switch via love-ui, for example it takes about 10 seconds and more until it is actually switched. All sensors and action takes long time. The love ui can also no longer be operated and runs extremely slowly. This is in my log. I don’t see any indication why?
2020-09-30 15:50:46 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for circadian_lighting which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-30 15:50:58 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for garbage_collection which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-30 15:51:06 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for remote_homeassistant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-30 15:51:07 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-30 15:51:09 WARNING (SyncWorker_4) [pyhomematic._hm] Skipping init for homeassistant-ccu3
2020-09-30 15:51:21 WARNING (MainThread) [homeassistant.setup] Setup of default_config is taking over 10 seconds.
2020-09-30 15:51:33 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform updater does not generate unique IDs. ID updater already exists - ignoring binary_sensor.updater
2020-09-30 15:52:00 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /discovery request
2020-09-30 15:52:00 ERROR (MainThread) [homeassistant.components.hassio.discovery] Can't read discover info:
2020-09-30 15:52:16 WARNING (MainThread) [homeassistant.helpers.service] Unable to find referenced entities light.living_room_2st_floor_couch_ambiance, light.living_room_2st_floor_tv_left_ambiance, light.living_room_2st_floor_tv_right_ambiance
2020-09-30 15:52:16 WARNING (MainThread) [homeassistant.helpers.service] Unable to find referenced entities light.kitchen_kitchen_block_ambiance, light.kitchen_kitchen_in_block_ambiance
2020-09-30 15:52:16 WARNING (MainThread) [homeassistant.helpers.service] Unable to find referenced entities light.stairs_up_ambiance
2020-09-30 15:53:05 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Timeout occurred while connecting to IPP server.
2020-09-30 15:53:26 WARNING (MainThread) [homeassistant.components.calendar] Updating google calendar took longer than the scheduled update interval 0:01:00
2020-09-30 15:53:51 ERROR (updater) [telegram.ext.updater] Error while getting Updates: Bad Gateway
2020-09-30 15:56:41 ERROR (MainThread) [pyhaversion] Timeout error fetching version information from Hassio,
Do you have any template sensors that start with “{{ states |…”?
If so then try removing them to see if your system performance improves. I had two of those and it literally made my system CPU use double and become very unstable.
