Updating Home Assistant Core - Stuck on Loading Data
Hey guys,
The past two times I have tried to upgrade home assistant core for the update for September and now I just tried October and both times Home assistant upgrades successfully. However, when I go to browse and login, it is just stuck at the loading data screen. I am able to even see everything popping up in the bottom left saying it has started successfully and my alerts and everything are working as expected but I cannot browse Home assistant.
I have tried dumping my browser cache, I have tried browsing via internal IP address and homeassistant.local but it is the same issue. I have tried via mobile and via pc. The only resolution I have is to revert to backup, but I don’t want to not be able to upgrade in the foreseeable future. Is anybody else running into this? I am running HASSOS in vmware on a windows pc. I have also tried rebooting the VM itself, as well as completely rebooting (and complete shutdown then power up) the windows pc as well but nothing fixes it.
I ran into the same problem after updating to 2024.10.3.
My HA is running on a RasPi 5
I also tried rebooting and all the other recommended steps. Nothing worked.
Home Assistant itself seems to run fine. My automations and connections to Apple Homekit are working. Only the front end ist stuck.
Sucks that you are going through the same thing as me, but also happy I am not the only one haha! Everything I was searching for online was from typically years ago and it was typically just a browser cache issue which this is not (have tried multiple browsers, incognito, multiple devices, etc). Even home assistant themselves recommend just dumping your cache when this happens to resolve which I have done multiple times.
By any chance do you have HACS installed or any other custom add ons? I was thinking of disabling those before upgrading the next time I try. I just don’t know when I will have a chance to do it again, because with mine being vmware I have to recreate the VM each time and then restore from HA backup which isn’t too bad but takes a little longer.
I was really hoping that it was a fluke with the September update like I said, but then ran into the same exact thing with the October one.
Do you guys see any information in home-assistant.log. Wondering if you might have the same problem as I have and if you have found a resolution yet.
Same problem also…
Thanks for your response @DBM that unfortunately isn’t my issue as I don’t have SolarEdge. I do think it has to do with a HAC integration though. I did give it another shot tonight and I tried disabling HACS along with all of the integrations as well that I have but that still didn’t work unfortunately so I have to work through another restore.
I think I may remove my HACS installs to see if it then works, but the problem is I won’t necessarily know which one causes the issue but it would still be a good test.
For the rest of you do you happen to use Music Assistant, Firemote Card, Team Tracker, or Team Tracker Card?
If we have a common HACS integration, maybe that will point to the issue.
did you try to do a safe mode restart to if that changes the behavior?
I do not have those integrations btw
I’m not sure this can help but I ran into the same problem after updating to 2024.10.3.
My HA is running on debian (Supervised).
I get this in my home-assistant.log :
File ā€œ/usr/src/homeassistant/homeassistant/components/websocket_api/connection.pyā€, line 227, in async_handle
handler(self.hass, self, msg)
File ā€œ/usr/src/homeassistant/homeassistant/components/recorder/basic_websocket_api.pyā€, line 31, in ws_info
if instance := get_instance(hass):
File ā€œ/usr/src/homeassistant/homeassistant/helpers/recorder.pyā€, line 76, in get_instance
return hass.data[DATA_INSTANCE]
KeyError: ā€˜recorder_instance’
I just rollback my last recorder configuration :
recorder:
  db_url: !secret mysql_connect
  db_max_retries: 20
  purge_keep_days: 30
  exclude:
    entities:
      - sensor.time
      - sensor.date_time
#      - device_tracker # This exclusion was rolled back
I am still getting this error on Home Assistant Yellow running 2024.11.1 - does anyone know of a fix?
I unfortunately haven’t had a chance to test again and it will probably be another week or two. Do you have any HACS integrations that I had listed previously by any chance? For my next attempt I am going to try and look at more of the CLI logs which I haven’t yet done. Also it was mentioned to try to start home assistant in safe mode which I am assuming you can try to do via the CLI as well so I may give that a try.
I will definitely post any updates on my next attempt.
I have tried in safe mode and I can access using my external domain still - but not on the local ip.
Looking back through your post @salok08228, I also use the Team tracker add-on and cards but that doesn’t seem to have any effect when in safe mode and also trying to access via the local ip.
Same issue here. Seems to happen when an update is available.
Secondly is Tuya in need of reautentication when loading hangs.
Hey guys,
Finally got around to trying to figure this out over the past couple of days and made a copy of my VM so I could more thoroughly test. @madjx you were correct!! When you posted last, I didn’t think I had done anything with recorder (and I haven’t in years) and so I embarrassingly glazed over your response because I didn’t think it was applicable to me. Truth be told I very rarely make direct changes to my configuration.yaml file anymore (used to do that in my early days with HA).
Anyways I ended up checking my configuration.yaml file to be sure and sure enough recorder was in there :expressionless: . After I commented out the recorder lines in my configuration.yaml and then rebooted the VM it came right up. Hopefully that helps others and if it isn’t recorder specifically maybe there is some other legacy stuff in your configuration.yaml file causing issues.
cheers @madjx thanks again and thanks to everyone helping point me in the right direction!!
Same problem here!
I updated HA Core to 2025.1.2 and now I’m stuck. tried on PC and iPhone. Running on RasPi.
Have the backup only on raspi I believe… is reversing and not updating the only solution possible?
Have you tried to review (or reset) your recoder configuration ?
Same problem here. Is there a small ā€œguideā€ for a non-programmer on how to fix this problem in the recorder config? I canĀ“t enter UI at all. Just stuck at ā€œLoading dataā€
Do you have a backup you can restore to? That is what I did because I didn’t have the ssh addon start automatically so I couldn’t use that. If you don’t have backups have you used or enabled the SSH addon and does it start automatically?
If you cannot get to HA through ssh then what kind of device is HA installed on a VM or is it a physical pi or hardware? If a pi you could connect the pi to a monitor and keyboard and then get to the CLI and modify the configuration file that way and comment out the recorder lines.
Let me know the answers to some of those questions and then based off that you should be able to research on other home assistant forums to get to the config.yaml file to modify it and comment out the recorder lines which resolved it for me.
Here is a link to modify the config.yaml from the CLI (command line interface)
Edit configuration.yaml with Hass.io CLI - Installation / Home Assistant OS - Home Assistant Community
Solved: Home Assistant VM Stuck at ā€œLoading dataā€¦ā€ Screen :clap:
A few days ago, I encountered an issue where my Home Assistant instance, running inside a virtual machine, got stuck on the ā€œLoading dataā€¦ā€ screen after startup. It wouldn’t proceed to the dashboard.
I followed a troubleshooting suggestion from salok08228 and successfully resolved the problem. Here’s the process I took:
  1. Booted the virtual machine using an Ubuntu live image, and entered the LiveCD environment.
  2. Located the configuration file at:
    /homeassistant/configuration.yaml
  3. Opened the file using a text editor (nano or vim) and commented out all the recorder related configurations (by adding # at the beginning of those lines).
  4. Saved the changes, shut down the Ubuntu live session, and restarted the Home Assistant virtual machine.
  5. The system booted up successfully and the frontend loaded normally!
Possible Cause:
It seems that the recorder integration was encountering an issue while accessing the database, causing the frontend to hang on the ā€œLoading dataā€¦ā€ state.
Takeaway:
If you run into a similar problem where Home Assistant gets stuck at ā€œLoading dataā€¦ā€, it’s a good idea to check your configuration.yaml, especially the sections related to recorder, history, and logbook, as these components rely on database access.
Many thanks to salok08228 for sharing the solution!
Awesome glad it worked for you! Cheers!
