Hello everyone, its been a little while since I last updated my HA. I am currently on core-2021.7.3 and OS 6.1. I tried updating today in the webGUI but seem to be having issues. So I installed the check home assistant config addon. This is what it found. Was hoping to get some help, thanks!
[09:56:11] ERROR: An error occurred while installing Home Assistant:
Looking in links: https://wheels.home-assistant.io/alpine-3.14/aarch64/
Collecting homeassistant
Downloading homeassistant-2021.10.6-py3-none-any.whl (14.2 MB)
ERROR: Exception:
File "/usr/local/lib/python3.9/site-packages/pip/_vendor/urllib3/response.py", line 437, in _error_catcher
yield
File "/usr/local/lib/python3.9/site-packages/pip/_vendor/urllib3/response.py", line 519, in read
data = self._fp.read(amt) if not fp_closed else b""
File "/usr/local/lib/python3.9/site-packages/pip/_vendor/cachecontrol/filewrapper.py", line 62, in read
data = self.__fp.read(amt)
File "/usr/local/lib/python3.9/http/client.py", line 462, in read
n = self.readinto(b)
File "/usr/local/lib/python3.9/http/client.py", line 506, in readinto
n = self.fp.readinto(b)
File "/usr/local/lib/python3.9/socket.py", line 704, in readinto
return self._sock.recv_into(b)
File "/usr/local/lib/python3.9/ssl.py", line 1241, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.9/ssl.py", line 1099, in read
return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
File "/usr/local/lib/python3.9/site-packages/pip/_internal/cli/base_command.py", line 228, in _main
status = self.run(options, args)
File "/usr/local/lib/python3.9/site-packages/pip/_internal/cli/req_command.py", line 182, in wrapper
return func(self, options, args)
File "/usr/local/lib/python3.9/site-packages/pip/_internal/commands/install.py", line 323, in run
requirement_set = resolver.resolve(
File "/usr/local/lib/python3.9/site-packages/pip/_internal/resolution/legacy/resolver.py", line 183, in resolve
discovered_reqs.extend(self._resolve_one(requirement_set, req))
File "/usr/local/lib/python3.9/site-packages/pip/_internal/resolution/legacy/resolver.py", line 388, in _resolve_one
abstract_dist = self._get_abstract_dist_for(req_to_install)
File "/usr/local/lib/python3.9/site-packages/pip/_internal/resolution/legacy/resolver.py", line 340, in _get_abstract_dist_for
abstract_dist = self.preparer.prepare_linked_requirement(req)
File "/usr/local/lib/python3.9/site-packages/pip/_internal/operations/prepare.py", line 467, in prepare_linked_requirement
local_file = unpack_url(
File "/usr/local/lib/python3.9/site-packages/pip/_internal/operations/prepare.py", line 255, in unpack_url
file = get_http_url(
File "/usr/local/lib/python3.9/site-packages/pip/_internal/operations/prepare.py", line 129, in get_http_url
from_path, content_type = _download_http_url(
File "/usr/local/lib/python3.9/site-packages/pip/_internal/operations/prepare.py", line 282, in _download_http_url
for chunk in download.chunks:
File "/usr/local/lib/python3.9/site-packages/pip/_internal/cli/progress_bars.py", line 168, in iter
for x in it:
File "/usr/local/lib/python3.9/site-packages/pip/_internal/network/utils.py", line 64, in response_chunks
for chunk in response.raw.stream(
File "/usr/local/lib/python3.9/site-packages/pip/_vendor/urllib3/response.py", line 576, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "/usr/local/lib/python3.9/site-packages/pip/_vendor/urllib3/response.py", line 541, in read
raise IncompleteRead(self._fp_bytes_read, self.length_remaining)
File "/usr/local/lib/python3.9/contextlib.py", line 137, in __exit__
self.gen.throw(typ, value, traceback)
File "/usr/local/lib/python3.9/site-packages/pip/_vendor/urllib3/response.py", line 442, in _error_catcher
raise ReadTimeoutError(self._pool, None, "Read timed out.")
pip._vendor.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='files.pythonhosted.org', port=443): Read timed out.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
