Updating Raspbee firmware
Hi
Is it not possible to update the Raspbee II firmware on an RPI running Home Assistant?
If it is, how do I do it?
I found this guide, and tried following the Raspbian guide, but in doing so realized I am probably not running raspbian, am I? :wink:
https://github.com/dresden-elektronik/deconz-rest-plugin/wiki/Update-deCONZ-manually
So I am now figuring the easiest way to update, is to remove the HA SD card from the RPI, insert a standard raspbian SD card, do the update from raspbian, and then re-insert the HA SD card?
Or, anyway to do it from within HA?
Have You solved it?
Another question, have you got it working at all?
I bought one RaspBee II last week, but I can’t gey it to pair with some Ikea buttons i also bought.
I can see the coordinator in ZHA, but nothing more. I have disabled the bluetooth. No logs comes out when trying to pair. I’m suspecting that maybe a firmware update can help.
/G
Just discovered that it got LQI set and RSSI set now! They have been zero since thursday! :slight_smile:
I will test it again when I come home!
No, it didn’t work :frowning:
Would love to know a solution for this myself. D:
Ya’ll running Home Assistant OS, right?
Here:
Uhhgm, ok here we go…
They should have made an easier way.
