I am running Zigbee/ZHA using the ‘Sonoff Zigbee 3.0 USB Dongle Plus V2’ with NCP firmware 7.3.1.0 build 176. I am experiencing some issues with devices dropping off and have already investigated other measures for improving network performance. Hence I would like to update the Dongle-E to the latest firmware.
I have a secondary Dongle-E unit which I would like to prepare with the latest firmware before swapping it with the ‘production’ unit.
Question 1: What would be the process for replacing the currently running Dongle-E with the secondary one, once updated? Will either of the options ‘DOWNLOAD BACKUP’ or ‘MIGRATE RADIO’ in the Zigbee ‘Network Settings’ page be required? Or can the sticks simply be exchanged while the HA unit is powered down?
Question 2: What are the considerations in choosing between firmware versions provided directly by itead (link - latest fw 7.4.4) vs. darkxst’s (link - latest fw 7.4.5)?
Question 3: Will the update necessitate any changes to the driver setting for EZSP vs Ember, or is this only needed when running z2m?
Question 4: The latest Home Assistant Update (2025.4) includes update functionality for HA Yellow Zigbee/Thread unit and HA ZBT-1 directly through Home Assistant. Considering that ZBT-1 and Sonoff Dongle-E share the same chip (EFR32MG21), will a similar update function be implemented for the Sonoff Dongle-E at some point?
Side Note: I did come across this related topic for updating the Dongle-E firmware in place, however it does not fully apply to my situation with the two Dongle-E sticks.
Why bother with the second dongle? Just upgrade the current one. Less trouble, and probably safer than going through the migrate process.
I use darkxst’s firmware, but still at an older version. I don’t know if there is any clear advantage either way.
Only a z2m thing.
I can’t speak to that. 2025.4 is not on my radar yet (I only update every 3-6 months unless there is a pressing need). I use the si labs updater addon.
It just seems like more trouble than its worth. I’ve done a few dongle-e firmware upgrades, and all have been uneventful in my experience.
The sticks can’t be swapped without migrating. You’ll end up with two adapters with the same ieee address.
That might cause problems if you want to redeploy the original as a router.
I assume the ieee can be changed with the router firmware, but I’ve never tried it myself. If it can be changed, I don’t know if it is a one time only change like the older coordinator firmwares, more dynamic like the new coordinator firmwares, or if it works at all. I assume it’s a one time only change, at least for the Sonoff 6.x router firmware. I haven’t seen a 7.3.x or newer router firmware, but I haven’t looked very hard.
So the course of action would be:
-Install Silabs Flasher Add-On
-Disable ZHA Integration
-Flash pre-existing Dongle-E with latest gbl firmware file
-Reboot(?)
-Re-enable ZHA
Just plug the dongle into the USB port of another PC and use the web flasher. Takes all of 2 minutes. Then plug it back into your HA rig and you’re done. might need a restart.
Just make sure you have the serial port drivers installed first.
You weren’t kidding - I did just this, pulled my stick from my HA box, plugged it into my Windows box (my desktop) and followed the link. Couldn’t have been easier and fixed my issue with Zigbee2MQTT not working!
Took me some time to get to it, but it worked for me as well (darkxst/s Silabs webflasher for Sonoff Dongle-E running Zigbee/ZHA).
I did shut down my HA server before unplugging the stick.
The Flasher I installed in HA does not update my Sonoff Dongle-e.
It is saying the Chip CH9102 is not supported.
It is a Sonoff Dongle-E about 2 years old now bought via Amazon.
Also, when I use the web flasher with the custom firmware, when I try to install zha it popup saying the firmware is not correct.
The strange thing is. I have two Sonoff sticks (one in production and one for testing). The production stick is working with multi stacks (Zigbee / Threat) although I do not remember updating that stick (???) and the stick in test seems not to support dual stack.
Any tips ??
I’ll keep testing and let you know what I discover.
Because I notice that Multi stack on the Dongle-E will be discontingud in the near future I thought I flash the OpenThreat stick and use one sick for Zigbee and the other for Thread. But I cannot install the OpenThread Border Router.
I tried as Url
